Crane Compucam
Car: 1986 IROC-Z
Engine: 383 TPI
Transmission: 700R4 2500 stall
Axle/Gears: 3.70 Moser 9in
Crane Compucam
Brand New installed but never ran. Its for the newer 305-350s that come stock with hydraulic roller.
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 2,000-5,500 RPM
Intake Duration at 050 inch Lift: 214
Exhaust Duration at 050 inch Lift: 220
Duration at 050 inch Lift: 214 int./220 exh.
Advertised Intake Duration: 270
Advertised Exhaust Duration: 276
Advertised Duration: 270 int./276 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.452 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.465 in.
Valve Lift with Factory Rocker Arm Ratio: 0.452 int./0.465 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible: Yes
Grind Number: 2032
Make an offer goes for 269.88 in Summit
pm me or email irocz86350@hotmail.com
Grind Number: 2032
Car: 1986 IROC-Z
Engine: 383 TPI
Re: Crane Compucam
Ok i have two now...One has about 1,000 miles on it ill sell it for 125+Shipping. The one installed but never ran ill let it go for 200+ shipping. These are roller cams so wear isnt a issue with 1000 miles. If you would like pics send me your email please. Thanks! Kenny
Car: 1991 Camaro Z28
Engine: L98 5.7 350 TPI
Transmission: Brand New (again) 700r4
Axle/Gears: GM 10 bolt 7.625 W/ TrueTrac 3.23
Re: Crane Compucam
How about 125 shipped for the one with 1000 miles on it?
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
