HSR Engine BRAND NEW
Old Dec 31, 2006 | 04:56 PM
DodgeTech's Avatar
i just got this thing built, its never been run. Was going to put it into my 2x4 truck but it got totaled so i bought a new 4x4 truck. Now i have a baby on the way so its got to go. The engine was pulled from an 89 GTA. i stripped it down to the block. It new has scoggin dicky vortech heads, XFI cam...i forget the grind i think its a 380 lift...(its something big) its bored .30 with forged speed pro pistons. .90 hardened push rods, scorpion roller self aligning rockers. Of course its got the HSR set up on thwere with the nice polished rails. The valve covers are polished aluminum, not steel. It has gear drives, not a timing chain, they are the machined ones that will produce a nice supercharger type noise. Erson timing cover.... i even went all out and got the ARP polished head bolts. Similar setups ive seen on this site are putting down over 400 hp and torque to the wheels. I have a BRAND NEW painless wiring harness, all the relays, pcm, MAF, and everything else needed to wire it up to any vehicle. it also comes iwth an MSD pro billit electronic advance and blaster 2 coil and MSD wires. it had ac delco rapid fire plugs in there now... the brackets and oil cooler lines have been powder coated silver. It also has the ac delete and smog pump delete on there. I know the connecting rods were balanced and the crank was growned i dont know if the crank was balance though. I hade the motor mout bracked painted gloss black in the body shop at my dealership. this engine is mint guys, its all set up all you need to do is get an MSD box and install this bad boy in your ride. the only thing i didt change was the fuel injectors... i replaced all the o-rings and i rebuilt the throttle body (gaskets and bolts) i even have all the thred to barb fittings installed. i have an oil switch still in the box thats ready to go on here too. i will deliver this for an extra 100 if your close by. i live in the boston area. im asking $3500 FIRM. no trades or other offers please. i have over 4500 in credit debt from this engine lol i need it gone. These pictures were taken before the brackets and acc. were put on ther. it currently has the brackets with alternator and delete pullies on there. I DO NOT have a water pump for the engine...
Old Jan 1, 2007 | 03:39 PM
DodgeTech's Avatar
oh BTW guys, i have 25 feet of black powder coated 5/16 fuel line and a brand new fuel pump that comes with this as well. the pump is a 3rd gen style pump but will also fit into GM trucks. i have steel 5/16 clips that will hold the line to the fram of the vehicl as well. if you guys need to see pictures of this stuff just ask
Reddeath210
Oct 6, 2015 08:20 AM
masonta
Aug 31, 2015 10:14 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
NinjaNife
Aug 23, 2015 11:49 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
