TH350 for third gen
Old Mar 7, 2007 | 12:21 PM
406GTA's Avatar
Car: 89 GTA
Engine: 406 SBC
Transmission: TH350
TH350 for third gen
I have a late 70's TH350 transmission. I bought it from a junk yard a while ago. It came out of a car with only about 50K miles on it. I put in a B&M shift kit, and ran it through both the radiator cooler, and an external cooler.
It currently has the B&M kit on it to be used in a 82-92 firebird or camaro. This kit enables it to bolt to the crossmemeber, as well as the torque arm.
I am going back to a 700R4 for the 4 gears and converter lockup. The transmission worked great when pulled from the car. I broke a small part of the flange on the bellhousing a while back. It has been professionally welded and will hold up to anything.
For $150 you get:
TH350 transmission with B&M shift improver kit.
Chrome pan with drain plug.
Transmission cooler
Correct taishaft for an electronic speedo
B&M conversion kit for Camaro/Firebird
Correct length driveshaft for camaro/firebird
I do not have a torque converter! I sold that seperate.
I will not ship unless you make arrangements for me to drop off somewhere, and I will charge to palletize.
Old Mar 9, 2007 | 12:11 PM
406GTA's Avatar
Car: 89 GTA
Engine: 406 SBC
Transmission: TH350
bump.
I would be willing to seperate the conversion kit from the transmission. It would be easy to ship, and you can find your own tranny.
Old Mar 10, 2007 | 12:00 AM
niceroc's Avatar
Car: 87 iroc
Engine: 454 .030 over
Transmission: th-350
Axle/Gears: 9 bolt
how much do you want for the conversion kit, everyhting but the trans, shipped to 60074?
Old Mar 10, 2007 | 06:39 AM
406GTA's Avatar
Car: 89 GTA
Engine: 406 SBC
Transmission: TH350
I figured it out on UPS.com For $40 plus $12.50 shipping:
B&M conversion kit
Tailshaft housing for electronic speedo
transmission cooler
For $50 plus $22.00 shipping:
B&M conversion kit
transmission cooler
Correct length drive shaft (adds weight and size to the box.
I also go to Milwaukee once in a while for work. You could drive there to pick the stuff up the next time I am there. I should be making a trip there in the mext month or so. I generally go about once a month.
Old Mar 10, 2007 | 02:13 PM
niceroc's Avatar
Car: 87 iroc
Axle/Gears: 9 bolt
would you be willing to take the whole trans and everything to milwaukee?
Old Mar 11, 2007 | 02:06 PM
406GTA's Avatar
Car: 89 GTA
Engine: 406 SBC
Transmission: TH350
No doubt. You would have to be very patient, because even though I should be going there in the next month. There is not gurantee it won't be a little longer. I would require some sort of deposit to hold it by then. I would prefer it would be done with something like paypal. If you are worried about me being trust worthy, my Ebay username is jbsooundguy
Old Mar 11, 2007 | 08:55 PM
niceroc's Avatar
Car: 87 iroc
Axle/Gears: 9 bolt
what kind of depoist are you looking to get?
Old Mar 12, 2007 | 07:11 AM
406GTA's Avatar
Car: 89 GTA
Engine: 406 SBC
Transmission: TH350
I would like $50 to hold it. After the deposit is paid, if either of us are not wanting to continue, I will be more than happy to refund your deposit. If you would like to talk about it, please give me a call. Justin @ 507-317-0664.
Hotrodboba400
Dec 10, 2019 07:07 PM
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
my86bird
Oct 23, 2015 12:20 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
