engine, trans, and ign system for sale
I decided to get rid of the stuff on my "project" thirdgen. I am going a different direction with it, so i need to get rid of the old stuff. Engine goes as follows:
350 4 bolt main .040 over w/flattops. COmp cams 280H cam, GM 434 heads with some porting (2.02 1.60 stainless one piece valves) crane cams pushrods, steel roller tip rockers, edelbrock single plane torker intake, edelbrock 750 carb. Also has summit chrome kit installed, engine painted orange. New water pump also. Has less than 125 miles on it.
Ignition: I would like to sell the ignition with the engine, but if someone doesnt want to buy it with the engine i will sell it seperate. I have a Mallory 85 series distributor, Mallory VI-A box and Accel super coil. Accel wires and AC Delco plugs all installed.
Transmission: TH350 professionally built by a guy in my town. Has a VERY firm shift kit (like bark the tires getting third gear at 80MPH with the engine above), it also has the 700r4 switch kit installed. This consists of a 700r4 output and tailshaft installed with a spacer. This way you can retain your stock torque arm and run the th350. It is a direct bolt in. this also has less than 125 miles on it. If you search the forum you will see there is a thread or two about this switch kit.
I have pictures of the engine and heads during assembly, so you can see the valves, etc.
MAKE ME AN OFFER I CANT REFUSE!!
ljnowell@yahoo.com
ljnowell@yahoo.com
Car: 87 TA / 87 Firebird
Engine: 385 FastBurn / Performance 3.4L
Transmission: TKO600 / 700R4
Axle/Gears: Ford 9" / GM 10bolt
Re: engine, trans, and ign system for sale
how much for the tranny... looking for one for my rebuild on a 305
thanks
thanks
Car: IROC/F250 7.3
Engine: LS12367
Transmission: Autos
How much are you asking for the engine w/o ignition? I am very interested.
Is there any way you would part the engine and sell the shortblock?
colton_carlson
Mar 8, 2019 12:21 PM
