'87 305 TPI and 700R4 FOR SALE!!! MISSOURI!!!
Old Mar 20, 2007 | 10:58 PM
92IrocRS's Avatar
Car: '92 RS ~ '92 Ranger
Engine: 305 TPI ~ 2.3 OHC
Transmission: 700R4 ~ Mazda 5-Speed
Axle/Gears: 10-bolt 3.23's ~ 7.5
I have an '87 305 TPI and 700R4 that was pulled from a wrecked Iroc. Both the motor and the tranny only have right around 60K miles on them, run and shift great. Fluids are very clean, no debris of any sort. I put new intake gaskets on because I cleaned up the intake and saw they needed replacing. I have the wiring harness and ECU with all of the connectors IN GOOD SHAPE!!! I also have a painless wiring harness for it that I never got around to installing if you would like to take that as well. Also has longtube Hedmann headers that are in decent shape, along with the accessories, p/s, water pump, alt., starter, belts hoses, etc., etc... Throttle and kickdown cable included. As for shipping, I dont have any way to do that, but I do have a cherry picker and will definitely help you load it up. Located in St. Louis, MO...
Asking $1200
PM me if you are interested, I'll be happy to answer any ?'s that you have, this is a very solid setup...
Old Mar 20, 2007 | 11:45 PM
92rs365hp's Avatar
Car: 2011 dodge journey
Engine: v6 vvt
Transmission: auto
Axle/Gears: ???
Re: '87 305 TPI and 700R4 FOR SALE!!! MISSOURI!!!
would you be willing to part with any of the wiring harnesses and comp??
what would you take for just the motor not the tranny??
Old Mar 20, 2007 | 11:50 PM
92IrocRS's Avatar
$700 sound reasonable for the comp, harness, and motor?
Old Mar 21, 2007 | 07:22 PM
92IrocRS's Avatar
Everything still up for sale!!! Would much rather sell it as a whole but if you need one or the other we can probly work somthin out!!! I need to get rid of these to make room for other projects!!!
COME ON GUYS THIS STUFF HAS LOW MILES!!!
Old Mar 21, 2007 | 11:12 PM
kelham's Avatar
Car: 87 TA / 87 Firebird
Engine: 385 FastBurn / Performance 3.4L
Transmission: TKO600 / 700R4
Axle/Gears: Ford 9" / GM 10bolt
how much for just the tranny....
Old Mar 22, 2007 | 12:15 AM
92IrocRS's Avatar
I would like $500 for the tranny, it has been treated well, and maintained extremely well.
Old Mar 23, 2007 | 11:18 AM
92IrocRS's Avatar
$1000 TAKES IT ALL!!! NEED TO GET THIS OUT OF THE GARAGE!!!
Old Mar 26, 2007 | 03:35 PM
92IrocRS's Avatar
SALE PENDING ON THE MOTOR!!!
TRANNY STILL UP FOR SALE!!! ~ $500 FOR A WELL KEPT 700R4
Old Apr 18, 2007 | 09:38 AM
CAMAROJOKESTER's Avatar
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
DO YOU STILL HAVE THE HARNESS.. IF SO HOW MUCH?
Old May 2, 2007 | 10:18 PM
92IrocRS's Avatar
Sorry I need to get rid of all of this at the same time.
NEW PRICE!!! $$$800 FOR BOTH MOTOR AND TRANNY W/ HARNESSES AND PCM'S, DRIVESHAFT WILL ALSO BE INCLUDED!!! I REALLY NEED TO GET THIS STUFF OUT OF MY GARAGE.
Old May 3, 2007 | 06:37 AM
JerseyMark's Avatar
Car: 1991 RS Convertible
Engine: 96 LT1
Axle/Gears: 3.45 9-Bolt
If you were closer.... This would be perfect. My motor has a rod knock.
Old May 7, 2007 | 06:10 AM
92IrocRS's Avatar
BUMP!!!
Old May 11, 2007 | 10:31 PM
airjordan6906's Avatar
Car: 1988 camaro rs
Were at is missouri comment back really need those engine and all
Old May 12, 2007 | 03:08 PM
92IrocRS's Avatar
Im in West County, maybe 45 mins max from St. Louis.
Old Jun 3, 2007 | 11:26 AM
92IrocRS's Avatar
BUMP!!!
$700
BUMP!!!
$800 TAKES EVERYTHING PLUS CROSSMEMBER FOR 700R4 AND HRADWARE!!!
I just pulled the oil pan to check the status of the rotating assembly, everything looks great and I put a new oil pan gasket and oil pan on.
Old Jun 7, 2007 | 01:40 PM
giovanniel11's Avatar
anyway you could ship to texas
Old Jun 9, 2007 | 01:10 AM
Imadude_134's Avatar
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
I know that you said that you cant/wont ship, but I am very interrested, but I am in Cali... and that sucks... So if you are willing to ship, let me know
Old Oct 25, 2009 | 06:14 PM
zzzzknightzzzz's Avatar
Car: 1992 RS CAMARO 25TH ANNIVERSARY
Engine: 305 TBI
im only interested in the 700r4 you said 500 right im from central mo about an hour 1/2 from st louis msg me if you got it
BlueIroc-Z
Jun 9, 2019 03:22 AM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
