SBC stuff- TBI- CHEAP
Old Apr 23, 2007 | 10:31 PM
cleetus's Avatar
SBC stuff- MSD/PBM springs/TBI- UPDATED 6/7/07
UPDATED 6/7/07:
-Complete TBI wiring harness cut at the firewall - $30
-810 heads - standard valves, no rockers, 65cc - $45
Hedman Headers - shorty style, came off a Monte Carlo. Small clearance dent on the #3 primary. I hit them with a light coat of high temp black. $50+ shipping.
880 roller block - 4 bolt main. No ridges on the cylinders. Was going to bore out and use for a 383, but I found another assembled 383. Oil pan also available. $150 + shipping
PBM3100 springs: 1.46 OD single w/damper. Used for 300 miles. Good to .550 lift- good for mild roller, or solid lifters. $55 No retainers or locks included.
MSD blaster SS coil and wire: $20 (bought from a guy on a different site who said it had 1 month on it. I haven't used it.) Wire has boot on one end, open wire on other.
MSD HEI cap for a Pro Billet distributor. Bought from same guy, same story) $25 - in original package.
MSD pro billet racing rotor- if you guessed it came from the same guy, you're right! - $25- in original package.
A/C compressor from early 90's Camaro(serp pulley). No idea if it works. $20
Items don't include shipping, and make an offer if you don't like the price.
Old May 7, 2007 | 07:04 PM
cleetus's Avatar
Re: SBC stuff- TBI- CHEAP
Also have:
stock driveshaft from an 86 TA with a 700r4- $10
oil pan, water pump, valve covers from above motor- make offer
Old May 7, 2007 | 10:34 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
do you have the tbi unit from the 350?
Old May 8, 2007 | 03:44 PM
cleetus's Avatar
I do. I'll send pics later tonight, or try to post them here.
Old May 8, 2007 | 04:10 PM
cleetus's Avatar
Old May 8, 2007 | 09:37 PM
johnnyboy's Avatar
what do you want for just the tbi unit? i think it might work well with my 305, but i'm not sure, i might need one from a 454
Old May 9, 2007 | 03:29 PM
cleetus's Avatar
Can do $30 shipped to you, if you're talking about just the 'carb' portion.
Old May 9, 2007 | 08:04 PM
johnnyboy's Avatar
$30 shipped sounds fair, will you take a money order?
Old May 10, 2007 | 05:33 AM
cleetus's Avatar
PM sent.
Old May 12, 2007 | 05:20 AM
cleetus's Avatar
Throttle body sold.
Make offers. I want this stuff gone.
Old May 16, 2007 | 08:39 PM
THIRDGEN87's Avatar
Car: 87 FIREBIRD / 89 TRANS AM GTA
Engine: Ls1 / 350 L98 TPI
Transmission: 4l60e / 700R4
Axle/Gears: 3.73 / 3.27
ANY PICS OF THE HEADS?
Old May 22, 2007 | 05:35 PM
cleetus's Avatar
I'll put head pics up ASAP.
Also for sale - serpentine setup from above motor. Includes 2 main brackets, water pump and pulley, alternator pulley, tensioner, PS pump and pulley, and crank pulley. Crank pulley has a tiny bend on one of the outside ridges, yet shouldn't affect anything. I can not vouch for the performance of the water and PS pumps. $85+ shipping.
880 roller block - 4 bolt main. No ridges on the cylinders. Was going to bore out and use for a 383, but I found another assembled 383. $175 + shipping
Old May 22, 2007 | 09:08 PM
71velle's Avatar
Car: 1971 Chevelle
Engine: 383
Transmission: TH350
Axle/Gears: 3.08 10 bolt, limited slip
how much would shipping to 29485 be?
Old May 22, 2007 | 09:27 PM
cleetus's Avatar
What would you like shipped?
Old May 22, 2007 | 09:34 PM
cleetus's Avatar
Old May 26, 2007 | 12:16 PM
cleetus's Avatar
Crank and rockers *SOLD*
Serp setup *Pending*
Anyone else want anything? Make an offer.
Old May 27, 2007 | 03:50 PM
RookieCamaro's Avatar
Car: 1992 Camaro RS
Transmission: 700-R4
Would you happen to have a MAF sensor for sale? and for how much.
Old May 28, 2007 | 11:13 AM
Pm gm's Avatar
Hello, how much for the hedman headers shipped to OH 44121 ? thanks..
Old May 30, 2007 | 12:33 PM
cleetus's Avatar
PM sent.
Old May 30, 2007 | 03:52 PM
dv8's Avatar
dv8
Car: 88 IrocZ Vert
Engine: 5.0 TPI
distributor & coil to 80233 and is the serpentine setup still avialable??
Old Jun 8, 2007 | 10:17 PM
cleetus's Avatar
New stuff bump.
Old Jun 13, 2007 | 07:53 PM
cleetus's Avatar
Bump. I want this stuff out.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
darwinprice
17
Oct 11, 2015 11:51 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Damon
Sep 26, 2015 04:29 PM
