tpi from 87 350 camaro
Old May 2, 2007 | 05:28 AM
Fastrucken's Avatar
This is a TPI setup from a 1987 Iroc camaro with a 350. It has not been installed since I had it powder coated metallic charcoal. There are no dents in the runners. This is an original MAF setup with a 9th injector setup which is included however I will include the 9th injector block off plate. Included is the rear fuel line fittings from street and performance. Also included is the original 350 injectors and an set of 21lb injectors from a 2004 mustang. A complete unmolested wiring harness is included. Things required to complete is either an EGR valve or block off plate, and a computer ( I was planning on a stand alone computer, megasquirt). Also would recommend a TPI bolt kit. One small flaw with the powder coat is I accidentally dropped the thermostat housing and chipped it. It probably would look better polished anyways but will leave that up to the buyer. Sensors worked when it was pulled from the car but that was some time ago, so are not guaranteed to work is also for sale on ebay with the auction ending on saturday.
400$ plus shipping
Old Jun 16, 2007 | 10:15 PM
95blue350's Avatar
Car: 95 C1500 Ext. cab
Engine: 355 TPI running on the TBI ecm
Axle/Gears: 3.73 GM 10-bolt
Re: tpi from 87 350 camaro
would you part out the injectors?
Old Jun 17, 2007 | 06:55 AM
Fastrucken's Avatar
Sorry sold it a couple of weeks ago
Graham
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
