Complete A/C System
Old May 6, 2007 | 01:50 PM
DNSTA's Avatar
Car: 1991 Camaro RS
Engine: 355
Transmission: 700-R4
Axle/Gears: 4.10
Complete A/C System
I've got a complete A/C system I want to sell. It's currently in a 1991 Camaro and is in perfect working order. It has been converted to 134 and was charged last year with coolant and seal conditioning oil. It worked perfectly all last year and worked fine when I tested it yesterday. It's still in the car so any pictures will reflect that but if anyone needs to see it let me know.
Please make an offer. I don't really use it that much and I would really like to be able to reach the #8 spark plug.
Old May 7, 2007 | 12:29 AM
rednblackrs's Avatar
Car: 01 mustang GT
Engine: 4.6
Transmission: tr3650
Axle/Gears: 3.73 Posi
Re: Complete A/C System
what are you looking to get for all of it. what all is included. I did the same thing you are doing and now I want my ac back.
Old May 7, 2007 | 06:34 PM
DNSTA's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 4.10
Honestly, I have no idea what I should ask for it all. $300.00?
Every piece of the system is included.
- Compressor
- Condensor
- Evaporator Core
- All lines and fittings
- Complete air box setup minus fan
- All electrical connections (not the wires that go to them but everything that is connected to the lines and compressor)
Really, it's the complete system ready to go. If you had A/C before and you didn't cut all your connectors off this is a bolt-in for you. If you did cut the connectors I can just cut off mine and connect them to the correct fitting and all you'd have to do is match wire colors with what's in you car. Pretty nice setup actually!
Old May 14, 2007 | 01:41 AM
Blown 346's Avatar
Car: 2000CamaroSS,69 Camaro SS,91 Camaro
Engine: 383
Transmission: TH 400
Axle/Gears: Stock
Will you do $300 shipped to 61111? If yes I will paypal the money to you.
Old May 14, 2007 | 04:25 PM
DNSTA's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 4.10
Yup, sure will. Let me know.
Old May 15, 2007 | 04:23 PM
Blown 346's Avatar
Engine: 383
Axle/Gears: Stock
Will the system still be charged once you remove it?
Old May 15, 2007 | 06:17 PM
DNSTA's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 4.10
No. The lines and all the system components have been removed. It would not be possible to keep the system charged and remove it from the car. It should take about 3 cans of coolant to fill it back up so about $15.
Terrell351
Jun 13, 2021 01:13 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Casey Meyers
Mar 2, 2016 10:46 AM
KO1
Aug 31, 2015 06:31 PM
