EVERYTHING from my SBC drag car project!!!
Car: 78 Malibu
Engine: 357
EVERYTHING from my SBC G body drag car project!!!
Don’t have time to finish my 78 4 door Malibu drag car project the way I would like to so everything I own race car related is going!!! Everything is for a SBC in a 78-88 G body, but much will fit F bodies and S10s as well! Located in 08080 South Jersey. I can get pictures of parts for those seriously interested.
JohnNeville@Gmail.com / 856 905 1908 cell
$3500--Intake to pan, a 357 small block with forged (Scat or Eagle, I forget) internals, 010 4 bolt block, 10:1 compression, Comp solid roller cam, Crower solid roller lifters, World iron heads, Crower roller rockers, double roller timing chain, Brodix HVH dual plane intake, SFI flexplate, 8” Fluidampr, etc. Had 3 runs on it after being professionally built when I bought it. It’s like new! I have since upgraded some parts. It's apart for inspection now. Puts out about 500 horses on pump gas!
$2000--NEW Hand ported 220cc Dart Pro 1s with 1.7 Comp Magnum rockers, girdle, coated 64cc chambers, cryogenically treated springs, raised letter "Chevrolet" valve covers, Manley undercut valves, steam holes, etc...
$600--carbon fiber driveshaft with 400 slip yoke 48.25” center to center
$500--MSD Programmable Digital 7+ 7530. No traction control detection to shut you down on this one.
$500--NEW Prince racing powerglide components. Billet dual Teflon ring servo and cover, probrake kit, hardened band adjuster, shift lever, complete rebuild kit, billet roller governor support, etc, etc…
$400--TCI circle track powerglide. 1.82 high and 1:1 low. th350 input shaft for working converter. Only a few nights.
$350--Jones wet belt drive
$300--NEW TRZ anti-roll bar kit
$300--NEW B&M carbon fiber powerglide pro stick with transbrake/nitrous button
$250--NEW Speedway Motors aluminum cross shaft chrome moly upper control arms, NEW upper and lower ball joints, NEW solid lower front control arm bushings, and stock lower control arms if you need them.
$225--NEW RCI 15 gallon aluminum sumped and baffled fuel cell with 0-90ohm sender
$200--NEW TRZ rear upper control arms
$200--Crower 290-66200 solid roller lifters.
$200--NEW Autometer 10K RPM silver face 5” tach with shift light.
$200--TCI??? 4000 stall 9.5” torque converter.
$200--Sweet Mfg 16.5” threaded end, power rack and pinion. Easily converted to manual by removing servo.
$200--Appleton billet manual rack and pinion, 18.5” center to center, tapered ends, 2.5 turns.
$175--MT 28x10.5 stiff wall slicks with 10 passes.
$150--NEW All Pro piston style mechanical fuel pump.
$150--Schneider roller cam 33350. .630" lift, 282@.050" duration, 322 adv duration, 112 LSA, 4000-8000rpm.
$150--NEW 2 Dynatech Split Flow 3.5” mufflers.
$150--NEW HAM solid body mounts.
$150--NEW MSD HVCII coil.
$125--NEW Scott under header SBC wires.
$100--New Comp Cams 7972 pushrods.
$100—NEW Fast Times Fabricated Powerglide deep pan.
$75--78 Malibu bare frame. Not bad, but some body mount holes in the rear aren't as round as they used to be.
$75--Comp Composites deep Powerglide pan.
$75--Front Moroso trick springs.
$75--QA1 coilover spring (12-130). Go in stock position. No shock needed.
$75--Wilwood proportioning valve
$50--Red CSR 4150 GM style throttle cable bracket.
$25--Moroso underdrive dual groove crank pulley for long water pump.
$25--Stock Malibu driveshaft.
$15--NEW short water pump single groove chrome crank pulley.
$15--NEW Wilwood drum brake residual pressure valve.
Car: 78 Malibu
Engine: 357
Re: EVERYTHING from my SBC drag car project!!!
All 4 shocks, the 8.5" rear, the 8.5" driveshaft, the TRZ bearings, and the Iceman arms are sold. The motor mounts and Manual brake set up are pending.
Car: 78 Malibu
Engine: 357
Updated the list!
Still waiting on 3 people to stop by so let me know what you want while it's still here!
Car: 78 Malibu
Engine: 357
Heads and a lot of other stuff should be sold locally this weekend. Let me know what you want! I'll trade the motor for a yfz450, raptor, or trx450r, if anybody has one???
Car: 78 Malibu
Engine: 357
I haven't bumped this waiting for some people to show, but those people are now no-shows so let me know what you all want. Might trade some stuff for a car trailer and I have 2 SBC motors for sale also:
http://www.racingjunk.com/post/90902...50-500-HP.html
Car: 88 Trans Am GTA 84 Camaro Z-28
Engine: L98 and a carbed 383
Transmission: auto but thats about to change
Axle/Gears: 4.11s
I have a 2006 ltr 450 i would be interested in trading however I could not trade even over The blue book on the quad is like $5700 would you be interested in a trade and some cash for the quad?
Car: 78 Malibu
Engine: 357
Sure, do you want any parts with the motor? We can work something out if you aren't too far away. PM sent
Car: 78 Malibu
Engine: 357
What is this "post and run" ****? I agreed so let's do a deal. At least get back to me about it???
PS: Building an 88 Notch now (I hope?)
Might trade for coil overs, rears, race brakes, etc, etc.
Car: 78 Malibu
Engine: 357
It was built for circle track and used for maybe 2 or 3 races. I never had the chance to use it for the track. I have all those parts from Prince Racing to make it a bullet-proof glide with a transbrake though. It should hold 500 horses as is.
Terrell351
Jun 13, 2021 01:13 PM
