race prepped th700r4 and 3rd gen drivetrain parts
Old May 22, 2007 | 08:35 AM
camaroracer1992's Avatar
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
Th700r4 transmission built for approx 800hp
Hardened input shaft/ Drum assembly (30 spline)
Extreme duty shell/bearing assembly
Extreme duty reaction carrier shaft and bearings
Extreme Duty rear 5 pinion planet gear
Extreme Duty front 5 pinion planet gear
TCI Reverse Manual Valve Body
Elevated Pressure Regulator Spring
13 Vane Pump Installed
29 Element sprag
10 Clutch pack installed (alto red)
Alto Carbon fiber band
Corvette Servo
0.500 Mega Valve
Polished Transmission Pan
Lokar Firewall mount dipstick
9” convertor (stalls at approx 3500 rpms) (this convertor has no lockup capabilities) - $1700/neg for everything listed above
Spohn Extreme Duty Driveshaft for 82-92 Fbody and t5/th700r4 transmission - $275/neg
Spohn Torque arm for Th700r4 transmission - $300/neg
contact me via email camaroracer1992@yahoo.com thanks!!
Old Jun 6, 2007 | 10:12 PM
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
Re: race prepped th700r4 and 3rd gen drivetrain parts
these are still available make me offers!!! this stuffs gotta go!!
Old Jun 6, 2007 | 10:34 PM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
Where are you located? Do you have the builder's sheet on the tranny? Has it ever been installed? How long ago was the build? Are you prepared to ship it?
Thanks, Nitro
Old Jun 7, 2007 | 03:40 PM
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
IM sent to neagan.
Old Jun 13, 2007 | 09:11 PM
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
still available make offers!!!!
Old Jul 25, 2007 | 09:53 AM
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
make offers this stuffs gotta go!!
Old Jul 26, 2007 | 10:37 PM
swanman133's Avatar
Car: 1984 Z28 Camaro
Engine: 355ci
Axle/Gears: Posi 10bolt 373
how much for the converter?
Old Jul 27, 2007 | 12:00 PM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
dude answer neagens questions here, other people r interested..
Old Jul 27, 2007 | 03:03 PM
84TranzAm's Avatar
Car: 84 TA Black/ Gold
Engine: 383 With Vortec Heads
Transmission: 700 R4 Lvl2 Performabuilt 9.5 Vert
Axle/Gears: Moser 9" with 3.70
Is the spohn torque arm adjustable and has it been installed before. Does it have a safety loop on it. What colour is it . Is this a tranny tail housing mount or mount to crossmember.
Old Jul 29, 2007 | 05:05 PM
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
no loop
red in color
yes its been installed
Old Aug 8, 2007 | 09:33 PM
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
TTT make offers!!
Old Aug 8, 2007 | 09:38 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
Originally Posted by camaroracer1992
no loop
red in color
is it still mounted on the trans or is this the one that is relocated to the frame mount or crossmember mount?
Old Aug 9, 2007 | 01:29 AM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Same question as Maroon and is it adjustable or fixed??
Old Aug 9, 2007 | 09:39 AM
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
adjustable torque arm
Old Aug 10, 2007 | 11:23 AM
Car: 88 IROC
i guess you arent too interested in selling?
Old Aug 10, 2007 | 12:10 PM
MemoryRacing's Avatar
Car: 85 Z28
Engine: 5.7
Axle/Gears: 4.11 10 bolt
Email sent about drive line.
Old Oct 1, 2007 | 10:44 AM
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
stuff is still available!!
Old Oct 8, 2007 | 09:22 PM
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
BUMP!!
Old Oct 9, 2007 | 05:40 AM
84TranzAm's Avatar
Can you post some pictures please of the torque arm and driveshaft. How long were both these installed for? What size of yokes are on the driveshaft are they oem size or did you upgrade any. I guess I am asking is it a direct replacement ? Pm me your best price on both shipped to 04730 . Thank you
Old Oct 9, 2007 | 08:50 AM
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
rear u jiont is a 1350, direct replacement
Old Oct 23, 2007 | 06:37 AM
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
taking offers on transmission/convertor!!! this stuffs gotta go!!
Terrell351
Jun 13, 2021 01:13 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
1nastygta
Aug 8, 2015 07:38 PM
