M112 Supercharger, Comp Roller Cam and Misc Stuff
Old May 30, 2007 | 02:29 PM
355SS's Avatar
Car: 90 Camaro
Engine: 418 LS3 whipple charged
Transmission: Magnum T56 w/ Street Twin
Axle/Gears: 3.27 9 bolt
1. 8 rib supercharger pulleys $35 ea.
2. Billet aluminum fuel filter and check valve $75
3. SBC Polished aluminum water neck $20
4. Tpi harness (harness has had all unneeded wires removed and reloomed) $125
5. APC 4 headlight harness for H4 swap $50
6. Bosch bypass valve for blower $50
7. Comp Cams Custom ground hydraulic roller cam (.544 I .556 E 230 I 236E 114 lope separation) $250
8. M112 supercharger, intake and fuel rails $1000
All parts are new except TPI harness
Pictures available on request
Old May 30, 2007 | 09:46 PM
Pm gm's Avatar
Re: M112 Supercharger, Comp Roller Cam and Misc Stuff
pm sent thanks..
Old Jun 12, 2007 | 10:39 AM
355SS's Avatar
Car: 90 Camaro
Bump
Old Jul 10, 2007 | 09:48 AM
355SS's Avatar
Car: 90 Camaro
Bump it is all going on ebay tonight
Old Jul 10, 2007 | 12:16 PM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
what application is the supercharger?
Old Jul 10, 2007 | 12:32 PM
355SS's Avatar
Car: 90 Camaro
The supercharger intake is for a sbc and the blower is a generic M112 same as what magnacharger uses. This setup requires additonal fabriaction to be able to use it. I did not finish the blower mount because I sold my 350 so I did not have away to finish verify the belt alignment. Also the air intake to the rear of the blower has not been started. I have the following parts I will include. Water neck, custom intake, custom fuel rails, brand new blower, aluminum for mountng plate, plenum, throttlebody, additional pulleys and a crank pulley. I am asking for less than I have in it, if it does not sell really soon I am going to split it up and sell it all on ebay.
junkcltr
Aug 2, 2019 11:12 PM
gixxer92
Sep 1, 2015 04:32 PM
mz92274
Aug 25, 2015 08:47 AM
anesthes
Aug 8, 2015 09:37 PM
