383 TPI Camaro parting out
383 TPI Camaro parting out complete car.. built 700r4, 92 iroc spoiler and GFEX.
Selling whole car for 4000 firm
MAKE ME AN OFFER ON PARTS YOU NEED PRICES ARE NOT FIRM.
I am willing to sell parts individually from engine, body and interior
Fast engines in Columbus, Ohio built engine
They are known all over for their engines
I will sell the engine for $1800 without tranny including all fuel injection and wiring
shortblock for $1200
or part out pieces call for prices.
Have all receipts of parts and engine work
77 Corvette 4 bolt-main block
Eagle 383 rotating assembly with H Beam rods
this is the 6" stroke kit not the 5.7. Gives more torque and power
Engine has been bored 30 over
Engine was balanced with harmonic balancer and flywheel
KB Hyper pistons
ARP stud bolts/ with windage tray mounts
Crane cams (mild cam for fuel injection)
New roller timing chain
High Volume z28 oil pump
Hooker shorty headers and Y pipe $100
Custom heated 02 sensors for headers $50
Ported and polished Intake Plenum and MAF sensor $100
Scoggin Dickey TPI Vortec intake\with 12 point intake bolts $350
TPIS adjustable fuel regulator $40
CRANE HEI high output spark coil $50
Polished Aluminum spark plug Holders $45
Moroso Polished aluminum Tall Valve covers $100
chrome timing cover/oil pan / dipstick /
new 400 harmonic balancer $100
165 degree water sensor. $30
Custom burned Chip by FAST engines $100
ValveTrain
$500
These heads flow better than the Dart iron eagles and the Elderbrock Etec
Vortec Heads with 2.02 Stainless valves, ported and polished with guide plates
Guides have been machined to accept around a .575 lift camshaft
$100
CAT Stainless roller rockers (1.6) ratio
$50
hardened pushrods
$900
Transmission
Have receipts
700R4 with all new Corvette internals built to withstand 500HP.
New clutch band , Drum, MOK, Sprag, Piston, Servos, Street shift kit, front pump, Filter, and gaskets
$150
2000 RPM stall converter
$1200 complete or part out
PICTURES OF INTERIOR CAN BE SEEN IN INTERIOR PARTS FOR SALE
THE USERNAME IS FLYINGHIGH23
New headliner that is plastic not cardboard
Brand New gray and blue custom leather seats from a 96 Camaro. I had these hand recovered and stitched to look like Ferrari seats. New Grey carpet
All plastics have been redone with new carpet and vinyl spray
$300
3.23 9 Bolt POSI rear-end disk brakes
$400
IROC Gold wheels with new Z rated tires
$125
Wings West 92 Z28 rear popup spoiler
Call on prices for what you need. all body parts are rust free.
custom door handles welded in from Maxima to give a sleeker look.
All Body and interior panels are for sale
TTops,Doors,Hood, Headliner, Quarter panels, Front and rear bumpers, Taillights
92 ground effects upgrade..
$90
Custom Grant chrome steering wheel.
call Mike for pricing and details @ 850-232-8027 or 850-983-4790
</O
KB Hyper pistons
ValveTrain
$500
$100
$50
hardened pushrods
$900
Transmission
Have receipts
$150
$300
$400
$125
$90
</O
Car: 88 Trans Am GTA 84 Camaro Z-28
Engine: L98 and a carbed 383
Transmission: auto but thats about to change
Axle/Gears: 4.11s
Re: 383 TPI Camaro parting out
How much are you looking to get from the engine and tranny
I would like $3000 for the engine and tranny. I have way over $7000 wrapped up into it. I still have all receipts from machine work and transmission rebuild. The transmission rebuild alone was $1300. I will include the headers, custom 02 setup and all wiring\computer intake plastic etc. thanks Mike
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
What year are the IROC rims and where in Florida are you located. Thanks. Adam :-)
They are 87 Iroc rims . I am asking 400 with the new tires. The tires are z rated. I am located in Milton,FL 32583.
I will be in Tampa, Orlando and Fort Meyers area July 23 for work so I can drop off parts to anyone interested in those ares. Thanks Mike
Last edited by flyinghigh23; Jun 27, 2007 at 05:34 AM. Reason: Automerged Doublepost
Have any pictures of the rims? Adam :-)
<---@gmail.com. Adam :-)
Car: 1988 Iroc-Z and 1985 Z28
Engine: Mild TT 355 and Built 383 Superchar
Transmission: Manual
Car: 88 IROC-Z twin turbo
Engine: forged 383 8-1 compression
Transmission: t56
Axle/Gears: 9in 3.50's trac loc moser axles
What compression ratio is the 383? thanks John
I calculated a DCR of 10.3 to 1 using the cam profile, head gasket thickness, stroke and bore to come up with this.. The pistons are flat tops with a -6cc valve recess. Thanks Mike
Transmission: t56
Thanks mike, I am running a supercharger so I think the compression is a little on the high side
I would be willing to sell just the block.. With 76cc heads you would be looking at 9.3 to 1..Depending on your cam if you use a little more radical cam than the one I have it would bleed off some DCR. I am not sure if that would be to high but I would be willing to pull everthing to facilitate your engine swap-over.. thanks Mike
Transmission: t56
just a bare block or the short block? thanks John
Car: 1992 Z28
Re: 383 TPI Camaro parting out complete car.. built 700r4, 92 iroc spoiler and GFEX.
how much for TPIS adjustable fuel regulator shipped to Postal Code L1C 2L7
Ontario, Canada
thanks
Ontario, Canada
thanks
Car: '01 Lincoln LS - '89 Camaro Z28
Engine: 350 c.i. 1 piece seal truck block
Axle/Gears: stock 2.73 gears stage II
Pm sent.
Car: 1986 camaro
Engine: 5.7 HSR
Transmission: 700-r4
Axle/Gears: 3:42 auburn
if you still have the 2000 stall? what brand is it? lockup for 700r4? I have paypal need converter asap!!!!!
Car: 1991 Camaro Z28
Engine: L98 5.7 350 TPI
Transmission: Brand New (again) 700r4
Axle/Gears: GM 10 bolt 7.625 W/ TrueTrac 3.23
Do you have the front lip for the ground effects??? Is it from 90-92? If so how much would you be asking plus shipping to 33472 boynton beach fl.....
Car: 1987 IROC Z28
Engine: 305/ 5.0
Transmission: 5spd Auto /700R
I need a complete wiring harness for my 87 IROC. It's got TPI, air, cruise, all the options. Everything from the firewall forward. I think the harness is in 3 sections. If you dont want to sell the ECM section then I'll take the remaining sections that run down either fenderwell. See PM for my addy.
Car: 1984 S-15
Engine: 1988 Iroc-z 305 V8
Transmission: T-5 (5-speed)
would you want to snip some connecters off the harness for me? i don't want to go paying 100's of dollers for new ones.
The_Phoenix
Sep 3, 2015 10:56 PM
