1.25 Valve Springs and Retainers
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
Chevrolet 283-400, Chevrolet 6 Cyl, Buick V-6 Lock Angle: 7° Valve Stem Size: 11/32'' Valve Spring Diameter: 1.250''
Steel Retainers
Item# 249-742-16
Only $62.99
**Mine $40 Shipped**
Seat Load: 105# @ 1.700'' Open Load: 295# @ 1.250'' Coil Bind: 1.150'' Rate(Lbs./In.): 423# Set of 16
Valve Spring Diameter 1.254'', Single Outer w/Damper
Item# 249-981-16
Only $62.99
**mine $40 Shipped**
Never Used But installed, Then I went with a bigger Cam. So I went with 987-16's dual springs, That is the box they will come in. They are perfect.
Crane 99051-1 - Crane Cams Valve Spring Shims
.030 x 1.480 x .703, 32/pkg.
Item# 270-99051-1
Only $19.99
**mine offer/package plus shipping**
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
