Comp Cams 08-306-8 Cam 290H-R12 ROLLER
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Was in my vette. Has less than 500 miles on it. $150 or best offer. Cost $260 new.
Hydraulic roller for OE roller blocks.
Part Number 08-306-8
Engine -Present Chevrolet
305ci-350ci
8cyl.
Grind Number CS 290H-R12
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.51 0.54
Duration At 0.006 Tappet Lift 290 307
Valve Timing At 0.05
Open Close
Intake 7 43
Exhaust 58 6
These Specs Are For The Cam Installed At 108 Intake CL
Intake Exhaust
Duration At 0.05 230 244
Lobe Lift 0.34 0.36
Lobe Separation 112
Reply here if your interested. PM me if we have a deal.
-- Joe
305ci-350ci
8cyl.
Description
Intake Exhaust
Open Close
Intake 7 43
Exhaust 58 6
Intake Exhaust
Lobe Lift 0.34 0.36
Lobe Separation 112
-- Joe
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Comp Cams 08-306-8 Cam 290H-R12 ROLLER
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
Do you think it would work with a maf set up?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
