COMPLETE 350sbc $2000obo
Car: 1986 Camaro
Transmission: wc t5
Axle/Gears: 9 bolt
350sbc $2000obo wc-t5 swap $500obo
I'm looking to sell the engine that is currently in my car. It has less than 500 miles on it. Engine pulls hard and I haven't had any problems with it, just going a different direction with the car. No real idea what hp/tq it is putting out, but guys have run 12s with similar combos on here.
If you need part numbers for anything I can dig them up. I'm selling this motor complete, intake to oil pan. Only things not included are the flex-fan, starter, flexplate, alternator, and ps pump. Only problem is the oil sending unit fitting broke off in the top of the block, but it does not leak any oil!
As I said its still in the car so I can take anyone for a ride, can't get on it too much considering the tranny is nearly gone though. After purchase I would need to pull it from the car. I would prefer local pickup buy might be able to deliver a short distance. No shipping. Located in Topeka, Kansas.
$2000obo
Engine:
- 350 2 bolt bored 0.060", honed, squared, and decked
- Melling standard oil pump w/ high pressure spring
- Cloyels roller timing chain/gears
- Chrome valve covers and timing chain cover
- Summit harmonic balancer
- Summit high flow iron water pump
- Carter fuel pump
Comp Cams XE-274-10 hyd flat tappet:
- Valve Lift .487" .490"
- Duration @ 0.050" 230° 236°
- Lobe Separation 110°
Heads
- Aluminum 64cc, 210cc intake, 2.02"/1.6"
- guide plates w/ screw in studs
- angle plugs
- 3 angle valve cuts
- Crower 1.5 steel roller rockers
Intake
- Holley 4160 600cfm, vac secondaries and manual choke
- Edlebrock Performer RPM Air-Gap
- 14x3 open K&N style filter
Ignition
- Proform new HEI w/ lighter springs
- Accel Wires
vid quality not that great, it seemed to pick up a lot of the fan noise
$2000obo
Engine:
- Carter fuel pump
Heads
- angle plugs
Intake
Ignition
- Accel Wires
Car: 1986 Camaro
Transmission: wc t5
Axle/Gears: 9 bolt
Re: COMPLETE 350sbc $2000obo
bump
also have a wc-t5 swap. everything except for pedals and shifter plate (console plastic). would rather not ship $500obo.
cj
cj
[ON] 9 Bolt Axles Partout
6speedIROC
16
Mar 15, 2023 08:33 PM
sailtexas186548
Feb 17, 2017 03:07 PM
topteam54
Oct 6, 2015 12:21 AM
