1987 gta 5.7 tpi harness uncut & 5.7 TPI engine
Old Oct 9, 2007 | 02:10 PM
89irocz355's Avatar
Car: 89 iroc/90 iroc conv./06 ram
Axle/Gears: 3.27/3.27/3.91
$150 shipped. $50 extra for computer
Old Oct 9, 2007 | 03:19 PM
89irocz355's Avatar
complete 5.7tpi motor in mass.
in a 90 formula. complete motor with serpintine setup. $600. or with speed density harness and computer $700. can hear run for a couple of seconds. gas line under car is leaking real bad but will start with starting fluid.
Old Oct 11, 2007 | 12:18 PM
86transamkid86's Avatar
Car: 1986 trans am
Engine: 305 tpi
Transmission: ?
Axle/Gears: 2.73/stoke/soon to be 3.47
Re: complete 5.7tpi motor in mass.
are you partin out the car and how many miles do you have on the engine im located in new bedford mass
Old Oct 11, 2007 | 02:47 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
i need the section of hard fuel line which connects the fuel rails to the rubber lines.the section i need runs behind the alt.how much shipped to 95901?thanks
Old Oct 12, 2007 | 07:42 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Interested in motor, Im located in Middleboro MA
Pics of the block, serial number an 5.7 etc would be great
Old Nov 3, 2007 | 01:57 PM
89irocz355's Avatar
motor is still for sale. $500 or $600 with harness and computer. also have tranny for $150 and rearend (3.23 disk 10 bolt) for $250. must pick up.
Old Nov 3, 2007 | 01:59 PM
89irocz355's Avatar
Re: 1987 gta 5.7 tpi harness, uncut
also same as a 88. comes with mass air flow.
Old Nov 4, 2007 | 11:08 PM
mxthreat's Avatar
Car: 86 iroc
Engine: 383
Transmission: automatic
Axle/Gears: stock
man i would give you 550 for it but i would need it to be shipped
Old Nov 30, 2007 | 03:40 PM
89irocz355's Avatar
still have motor. $400. complete motor with serpintine. runs great. $500 with harness and computer. out of car and in garage now.
Old Nov 30, 2007 | 03:41 PM
89irocz355's Avatar
still have it...
Vintageracer
Jan 10, 2020 05:33 PM
beachrodder
Aug 25, 2015 08:05 AM
jharrison5
Aug 19, 2015 05:53 PM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
