91 Z28 3:23 Disc posi 10 bolt PBR complete in GA.
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
With 121K with no noise. This is complete with booster, MC, proportioning valve, disc, calipers, emergency cables, brake lines disconnected at the flex line that is mounted to the body in the back and sway bar, end links and attach brackets. This is a southern car with no rust. Still in the car but, will be removing shortly and then I'll post some pics. I will not crate it to ship but if you can find someone coming thru Atlanta that has room for it I will ship it that way. $500.00
Terrell351
Jun 13, 2021 01:13 PM
ambainb
Apr 25, 2016 09:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
