Tpi setup.
Old Jan 14, 2008 | 11:04 PM
Formula350Scott's Avatar
Tpi setup.
Hey all, im considering selling my factory tuned port intake since its just sitting on a shelf. The plenum has been ported out and the base has been siameased (sic) over halfway into the ports. I can stick my whole hand in there. It gave my car a noticeable gain over stock. It didnt hit that tpi brick wall at 4800 rpms. It will come with the base, runners, plenum, fuel rails and regulator, water outlet, and distributor cover. Its off an 89 model formula so theres no cold start injector. It uses stock gaskets but you would have to cut the centers out of the base to make them oval shaped. I'm asking $150 obo. I'll get pics of it tomorrow.
Old Jan 15, 2008 | 06:49 PM
rplettermen's Avatar
Re: Tpi setup.
waiting for pics
Old Jan 16, 2008 | 11:26 PM
Re: Tpi setup.
There are some pics of the intake. There is one stripped bolt hole (the bottom of the three that holds the throttle bracket on) and one that i had a standard bolt in on the drivers side rear runner. The distributor cover comes with it but is not in the pics. Also the base could be ported and siameased even further and i forgot about my DIY adjustable fuel pressure regulator that goes with it.
Old Jan 17, 2008 | 07:04 AM
dberry's Avatar
Car: 89 Firebird Formula 350
Engine: 5.7 liter 350 tpi
Transmission: 700 r 4
Re: Tpi setup.
how much shipped to 65251??
Old Feb 16, 2008 | 11:37 PM
Re: Tpi setup.
Back up. Make Offer.
Old Feb 17, 2008 | 05:40 AM
bonesbrakr's Avatar
Re: Tpi setup.
If you can do $150 shipped let me know and i can Paypal right away.....
Bill
Old Feb 17, 2008 | 10:38 AM
Re: Tpi setup.
PM sent.
Old Feb 17, 2008 | 01:28 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
Re: Tpi setup.
i'd go 165$ shipped to 43056 and you can keep the rails the egr valve and the water neck if you can get any use out of them as they will just sit considering what i currently would be needing is only a manifold so i dont have downtime porting my current 1 on my car while i do a heads and cam swap.
Old Feb 17, 2008 | 05:45 PM
bonesbrakr's Avatar
Re: Tpi setup.
Scott is a good guy and a man of his word..... i will back out and let Flaming have the intake.... good luck with the sale.....
Bill
Old Feb 17, 2008 | 06:23 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: Tpi setup.
well is it sold? Let me know,I am int. in the complete setup.
Old Feb 18, 2008 | 12:11 AM
Re: Tpi setup.
Sold pending payment.
customblackbird
Aug 15, 2021 10:16 PM
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
Sanjay
Aug 12, 2015 03:41 PM
