Sub-Frame
Old Jan 19, 2008 | 09:04 AM
83camaro86's Avatar
Car: 2001 Jeep 1984 S-10 daliy drivers
Engine: 1983 has a 305 1984 Trans Am
Transmission: 1983 has 350 tubo 1984 Trans Am
Axle/Gears: stock
Sub-Frame
I have a set of sum-frame connectors from Summit Racing. This are the bolt ones. I guess you could also weld if wanted. They are the heavy duty ones. I would like to get 200.00 not including shipping. This are like new with all the bolts. May need some new paint due to being on the car for about 5 mounths.
They run about 270.00 or so at Summit.
Old Jan 19, 2008 | 05:45 PM
83camaro86's Avatar
Axle/Gears: stock
Re: Sub-Frame
Anyone need???
Old Jan 19, 2008 | 09:35 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
Re: Sub-Frame
Guys those to me are the best subframe connectors you will ever find. The only problem is on the right side, you will need to cut the pieces that go from the sill to the center member and weld in flat steel pieces. Then, you will have something that no other company can come close to. I have been dealing with them for a number of years and you wont come close to finding a better set.
matty350TPI
Apr 2, 2024 07:05 PM
vjo90RS8
Dec 13, 2001 10:48 PM
MilehighBird
Carburetors
Dec 12, 2001 12:31 PM
leirch
Nov 30, 2001 03:16 PM
cobrakiller1989
Oct 13, 2000 11:48 PM
