New & Used Sm Block Chevy / 3rd Gen Camaro Parts at VERY Cheap prices
Car: Dark Blue 1987 Chevy Iroc-Z Camaro
Engine: 5.7 350
Axle/Gears: 3:42
Forsale are the following parts for and from 3rd gen camaros (mostly an 350ci Iroc-Z. If you have any questions I can be contacted at coreyace@ptd.net and if wanting pictures fell free to ask.
Complete Serpentine/VBelt Pulleys and brackets includes $60
-Ac compressor pulley
-alternator pulley
-power steering pulley
-water pump pulley
-2 crank pulleys one serp other serp and V-belt
Stock Ring and pinnon gears (7.5 rear 3.23 ratio) $35
Brand new Pistons and rings for a 355 (speed pro 10.2:1 comp ratio with 64cc heads) $75
Brand new stock timing chain $10
T-Tops in perfect condition included right and left $50
Oil pan $15
brake resevior and boost $30
Xlerator High performance muffler single in dual out $30
6 15" standard camaro Rims with no tires installed $30 each
stock LB9 Heads with valve assembly still installed $40 for set
stock coil and fuel pump $20 for set
Brand new stock cam for 350(never been used) $30
Fel-Pro complete intake gasket set (All gaskets for stock TPI unit) $25
Fel-Pro head gaskets (P/N 7733 PT-2) $15
2 sets of Fel-Pro Rubber valve cover gaskets $15
Brand new holley adjustable FPR for the stock TPI intake $60 thats $40 off new
Holley EGR Block off plate for stock TPI intake $10
-alternator pulley
-water pump pulley
Oil pan $15
Engine: 5.7 350
Axle/Gears: 3:42
Re: New & Used Sm Block Chevy / 3rd Gen Camaro Parts at VERY Cheap prices
P/N = 844-345NP40
Jegs has more specs at this url
http://www.jegs.com/webapp/wcs/store...44636_-1_10219
9192camaro
16
02-03-2019 12:21 AM
Zachattack0925
08-12-2015 09:54 PM
Zachattack0925
08-12-2015 09:52 PM
