700r4 (parting out car)
Car: 86 camaro
Engine: 385
Transmission: glide
Axle/Gears: moser 12 bolt spool 4.11
got an 87 camaro, 305 carbed, 700r4 selling the trans drove the car last week it shifted great and locked up fine, no shutter, no slips, nice positive shifts into ever gear. like to get $150 for the trans also parting out the car tell me what you need. has 16x8 eagle alloys. (torque thrust II look alike) with brand new 245/50/15 kumho esta ast's no miles just mounted. like to get $600 for wheels and tires.
Car: 87 iroc
Engine: 5.7 ZZ4, AFR, Stealth Ram, Comp cam
Transmission: 1993 T56 viper internals w Spec3+
Axle/Gears: moser 9" truetrac 3:89
Car: 86 camaro
Engine: 385
Transmission: glide
Re: 700r4 (parting out car)
deltona, fl zip code 32738. wheels are on the car i can send a pic of them on mine.
Car: 86 camaro
Engine: 385
Transmission: glide
pics sent. if anyone wants the whole car $1000 takes it. it did run and drive took the motor out because i believe its got a cracked head. needs a paint job but the body is fairly straight.
Car: 87 iroc
thanks I got the pix. Is that rim just dented and not bent that might cause a vibration.
Car: 86 camaro
Engine: 385
Transmission: glide
its dented on the lip. i can take a pic for you if you want. it holds air fine and never effected anything. it didnt cause a vibration but its hard to tell because my car has always had vibrations due to rod end suspension. but no it didnt add vibrations.
Car: 86 camaro
Engine: 385
Transmission: glide
its got the factory 4 barrel. quadrajet. it was recently rebuilt. dont think the car has the air pump. i believe it was removed.
Car: 86 Trans Am
Engine: 350 Roch-4bbl
Axle/Gears: Normal
Car: 86 camaro
Engine: 385
Transmission: glide
i didnt the car has 16x8s why did i post that they were 15s? the wheels are sold anyway.
the carb is the late model computer controlled.
Iroc8t8
May 4, 2026 08:09 PM
