86-88 complete TPI setup
Car: KITT
Axle/Gears: 2.73 one wheel wonder
I have a complete TPI setup suited for conversions,
Entire TPI assembly- Intake, runners, lower manifold, aluminum vette dizzy cover"except for the manifold all powder coated gloss black" high pressure fuel pump, strainer, wiring harness, MAF sensor, throttle cable, kick down cable, HEI dizzy, injector rail with injectors, 52mm throttle body with powder coated cover plate, a few other sensors still attached to the intake, serpentine metal fuel lines.
The working condition of the wiring harness is questionable but all the sensors and fuel pump are new.
I'd let it all go for $600 plus shipping
22x10x30 62lbs
22x10x30 62lbs
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
Re: 86-88 complete TPI setup
if you're willing to seperate i'd be willing to take the complete manifold itself off your hands along with the aluminum dizzy cover plate. may also take the tb depending on what you would want for it. I'd need pics though. Any porting work done? i have an 89 maf setup but, am going to be switching to earlier styled heads so providing i can plug the coldstart injector hole i'm all for it.
wouldnt need dizzy, throttle brackets, wiring harness or any of that sorta stuff.
lmk via pm on a price if you're willing to seperate thanks.
Car: 1987 Pontiac Trans Am GTA
Engine: 350(L98)
Transmission: 5spd manual
If you do plan to separate, I would be interested in the maf and the throttle body.
- Paul
- Paul
Terrell351
Jun 13, 2021 01:13 PM
