2- 82-92 Third Gen 9 inch rearends
1st- this is a setup i built myself a few years ago and have ran several 9 sec passes on. 9 " rearend with torque arm, spohn single adjustable lower control arms, anti roll bar (you will have to weld two bolts onto the subframe to catch the adjustable heims), lower control arm relocation brackets, moser 35 spline axles with bearings and no studs (about 6 months old)
I'll throw in an old stock third member with 4.11 gears (it needs a new spool and rebuild kit) This rearend is powder coated silver grey. I went a bunch of 1.29's 60 ft with this setup and it is all still in the car to check out. You will have to make and weld in a simple cross member for the torque arm bar to mount to.
750.00 Pick up only preferred
2nd- 9" Moser housing with all brackets and torque arm bracket.
You will need your own axles and bearings , third member, housing ends etc.
500.00 Pick up only preferred
Located in Wixom , MI
please email creetz77@gmail.com for pics
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
Re: 2- 82-92 Third Gen 9 inch rearends
could you send some pics, pm is fine or Rippedtornheart@yahoo.com... I am in Mansfield, Ohio So I could probably pick it up... I am interested in the silver one...
Transmission: t-5
i spoke to you on the phone. consiter the silver one sold. Ill pick it up after your trip! please keep in touch.
Transmission: 4l80e
If that false through, I will buy the silver setup and pick-up... I have plenty of money... but I do work a very weird schedule that's why I haven't called... will also pm you.... thanks
Terrell351
Jun 13, 2021 01:13 PM
