FS: 87 camaro 305 TPI intake system (no dist/harness/ecm)
Subscribe
Apr 20, 2008 | 03:53 PM
Everything is from a 87 camaro 305. This system includes the following:
- base intake manifold (for 87+ heads, but center bolt holes can be easily drilled to work on pre-87 heads)
- all sensors on the intake - ECT, IAT, cold start injector switch, EGR valve with temp sensor
- runner tubes - a couple VERY minor dings, worst one is less than 1/8" deep
- plenum with distributor cover
- set of new runner to plenum gaskets
- dual 48MM throttle body with air foil, IAC motor, TPS sensor
- fuel rail including injectors (stock 19.3 lb/hr) and cold start injector
- throttle cable bracket
- lots of extra bolts, including manifold to head bolts
Everything is stock, unported.
No distributor, harness, or ECM.
Looking for 225 OBO plus shipping.
Reply 0
Subscribe
