ALUMINUM INTAKE MANIFOLD ALSO LT1 CAM
Car: 87 FIREBIRD / 89 TRANS AM GTA
Engine: Ls1 / 350 L98 TPI
Transmission: 4l60e / 700R4
Axle/Gears: 3.73 / 3.27
hey guys. i have a new manifold and a lt1 cam for sale. 1st the manifold is new in the box. i went with a single plane manifold and no longer need this one. asking 80.00 specs below:
i also have a lt1 cam from a 1995 camaro. again i went with a larger cam. and no longer need this one. it is in good shape with no grooves on the lobes. good wear. excellent replace ment for the 305 guys. asking 20.00. 30 total shipped in the u.s. thanks for looking.
manifold specs:
Power Plus Crosswind intake manifold by Professional Products for Chevrolet small block engines. Similar to the Typhoon intake manifold, but the Crosswind features an open area under the plenum chamber. This provides for a flow of cooling air which keeps the temeprature of the air/fuel charge lower thus producing more power and torque. Show polished finish at an affordable price! Power range of 1500 rpm to 6500 rpm. Four corner water outlets and dual distributor holddowns. Deep dual plane design. Square bore carb flange works with Holley, Demon, Edelbrock and Carter carburetors. Fits 1957 to 1995 small blocks. Will not fit 1992 and newer LT-1 enignes. Street legal for non emissions equipped or controlled engines or vehicles. Measures 4.65" tall at it's tallest point and has ports measuring 2.09" high and 1.25" wide.
Power Plus 52026 Crosswind Chevrolet small block intake manifold Professional
retail: 164.99
manifold specs:
retail: 164.99
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
Re: ALUMINUM INTAKE MANIFOLD ALSO LT1 CAM
so that cam is a good replacement for 305s? no machingin needed to the heads or is there stuff needed to be done?
sale pending on both. i will post if either fall through. thank you.
Car: 1986 WS6 TransAm
Engine: THREEFIDDY!
LT1's are still 1.5 rocker ratio so you wont have issues, and depending on the millage on the car.. i would buy a pair of valve springs from comp.. $50 on ebay.
cam sale still pending. will advise if falls through. waiting for payment. i thank you all for your intrest.
payment for intake received shipping tomorrow.
ambainb
Apr 25, 2016 09:21 PM
