1992 small cap efi distributor
Old May 5, 2008 | 09:04 PM
lt1z350's Avatar
Car: 92 formula, sd,730ecm with $59
Engine: 383/ t-76 turbonetics
Transmission: 700r4 3200 vig converter
1992 small cap efi distributor needed for hsr install
near new reman distributor off my 1992 formula. I got it under warranty right before it was up so I had a new one put it in and then got hooked up by a freind with his msd billet one so took it right back out. It has surface rust on it that it had when I got it from the warehouse. The accel cap and rotor might have 5k on it the actual unit might have 2 or 3 k on it. Gear barley worn. It worked great of course as it is new. Cost me 105 and like to get 50 back on it + shipping.
Attached Thumbnails 1992 small cap efi distributor-car-parts-029.jpg   1992 small cap efi distributor-car-parts-030.jpg   1992 small cap efi distributor-car-parts-032.jpg
Old May 5, 2008 | 10:12 PM
spills's Avatar
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
Re: 1992 small cap efi distributor
From the looks of it, it is a full electronic advance dizzy, correct? No mechanical or vacuum advance? And is that a 7-pin or 8-pin module? I think this might be that last part I need for my HSR install
Old May 6, 2008 | 11:54 AM
lt1z350's Avatar
this is what you need. I have the same set up on mine just have the msd billet one now. it is 4 pins in one and 2 on the other. a stock 92 set up. let me know intrest is very high and I expect to go fast.
Old May 6, 2008 | 12:48 PM
spills's Avatar
Car: 89 RS
awesome! I cant do paypal at work (firewalled), so if you can hold out till later on this evening, Ill paypal ya
Old May 6, 2008 | 02:29 PM
lt1z350's Avatar
ok lt1z350@bellsouth.net for paypal. 10 to ship and I will do priority mail. 60 total.
thanks
Need any 30 lbs injectors?
Old May 6, 2008 | 02:40 PM
spills's Avatar
Car: 89 RS
nope, already got some SVOs. Thanks though!
Old May 6, 2008 | 07:14 PM
lt1z350's Avatar
sold
Vintageracer
Jan 10, 2020 05:33 PM
junkcltr
Aug 2, 2019 11:12 PM
1992CamaroGirl
Dec 25, 2017 08:45 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
