Crane Hi-6TRC CD Ignition (in car timing retard) and LX-92 race coil
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
Used, but removed working great. I was very pleased with the box on 10 second street car. MUCH better than my (3) former MSD Digital 6s and has been flawless. $280 shipped, paid $390, have original boxes and manual. I believe there is an optional MAP sensor for variable retard with boost.
http://www.jegs.com/i/Crane/270/6000-6466/10002/-1
http://www.jegs.com/i/Crane/270/730-0892/10002/-1
From Jeg's description:
This multi spark CD ignition can handle anything from street applications to race setups with 14.5:1 compression, nitrous-oxide, superchargers, or turbos. It produces more HP, torque, and will give your mean machine crisper throttle response. It delivers more spark-gap current than any comparable digital CD ignitions on the market! There is a built in timing retard available with the optional control module, P/N 270-6000-6425. The plug-n-go harness is included with the ignition box. The HI-6R includes a built-in tach accuracy check as well as a sequential rev limiter to stop engine damaging ''popping and banging'' when it hits the rev limiter. The big rotary switches are precise and ease rev limit adjustments with their ''click-in'' accuracy, eliminating the need for RPM chips! Includes shock mounts for race conditions and is fully potted with new, soft urethane for heat, dirt and moisture protection. It can be used with a points, mag, or module triggered ignition. It also has a new feature that uses built-in flashing codes that tell you if there is a problem whether it's the coil, ground, power supply, loose or broken wires, or the ignition unit itself! This box also features an exclusive Cross-Fire protection for supercharged or turbo applications. HI-6TRC includes timing retard control.
Car: 1991 Firebird
Engine: 427 LSX
Re: Crane Hi-6TRC CD Ignition (in car timing retard) and LX-92 race coil
TTT, accepting offers.
J. May
J. May
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
still got this setup?
Ghettobird52
Jul 5, 2024 11:18 PM
Terrell351
Jun 13, 2021 01:13 PM
9192camaro
16
Feb 3, 2019 12:21 AM
