trans go full throttle up shift for overdrive kit.
Car: 92 formula, sd,730ecm with $59
Engine: 383/ t-76 turbonetics
Transmission: 700r4 3200 vig converter
It is a transgo gil younger kit for 87 and earlier valve bodys that wont shift to over drive under full throttle. Sucks to be whipping up and a bike and run out of gear because the car wont stay in over drive. If you car falls out of od when at full throttle and wont upshift until you back off to 3/4 you need this valve no matter the year of the car. It was for any 87 and lower transmission that came stock with out it. any questions please ask. i take pp and it is 15 bucks for it think it was 30 or 40 new and is new still.
Car: '87 Iroc-Z
Engine: 355cid Cam'd
Transmission: T5 Manual
Axle/Gears: Stock 9 Bolt
Re: trans go full throttle up shift for overdrive kit.
my camera is charging still. It goes in the valve body itself. You have to remove it to install. like a shift kit.
1992 Trans Am
May 10, 2023 07:19 PM
theshackle
Sep 17, 2020 08:26 AM
maroe624
Apr 16, 2017 08:29 AM
dhonda200
Aug 11, 2015 11:50 PM
