Fresh 700r4
Old May 18, 2008 | 08:02 AM
Cgroh89's Avatar
Car: 92 rs stock 93 ta mildly modded
Engine: lt1
Transmission: 700r4 and m6
Fresh 700r4
Pulled from a 93 bird with 55k on it.
Rebuilt using a Transtar rebuild kit and a B and M shift kit.
I built this last semester in school when I was still doing my lt1 swap. I have a m6 now and I have no use for it. And I sold my camaro
Most everything was done by my teacher with me watching and learning.
It was torn down and cleaned all the way to the valve body. to ensure no sticking valves or disk material left inside and the case was steamed cleaned 3 times since I didnt want anything to go wrong.
Everything was checked with air to ensure the clutch packs held etc.
I have the shift linkage and cooling lines along with the stock converter if you want it, Though I can get a new one pretty cheap through work which I would suggest.
Looking for 700 obo. Id prefer local pick up
In Ottawa Illinois. Id be willing to meet up you with We would just have to work something out
Old May 21, 2008 | 09:23 PM
Cgroh89's Avatar
Engine: lt1
Re: Fresh 700r4
Bumps
Old May 24, 2008 | 09:45 PM
snake70's Avatar
Car: 1979ta, 1981 formula
Engine: 400 sbc 403 olds
Transmission: th350 th400
Axle/Gears: 308 373
Re: Fresh 700r4
a 700r4 in a 1993? should be a 4l60e
Old May 24, 2008 | 10:12 PM
Cgroh89's Avatar
Engine: lt1
Re: Fresh 700r4
Its not most in 1993 were the 700's in 1994 all of them were.
It was going in my Thirdgen But I sold it before I put it in and Im getting sick of forth gens very much
Old Jun 1, 2008 | 03:09 PM
Cgroh89's Avatar
Engine: lt1
Re: Fresh 700r4
Bumpage.
Make me an offer, Ill proly take it as long as it covered my cost somewhat
Old Jun 1, 2008 | 04:54 PM
snake70's Avatar
Axle/Gears: 308 373
Re: Fresh 700r4
do tou have a pic of it lookin for a cheap one
Old Jun 1, 2008 | 08:05 PM
Cgroh89's Avatar
Engine: lt1
Re: Fresh 700r4
Sure Ill snap a few in the morning
Old Jun 2, 2008 | 05:39 PM
Finetunedz28's Avatar
Re: Fresh 700r4
Interested too. I live about an hour away from ottawa. Give me your best price.
Old Jun 2, 2008 | 09:01 PM
Cgroh89's Avatar
Engine: lt1
Re: Fresh 700r4
Send me a pm Where do you live I can meet ya half way I wasnt able to get over to the shop today after work to snap a pic though Ill be out there tomorrow to bring it home,
Old Jun 3, 2008 | 10:56 PM
Cgroh89's Avatar
Engine: lt1
Re: Fresh 700r4
Here are the pics , I was going to clean the case I thought the out side would have came cleaner in the steam cabinet As well I have the stock converter if you were going to have it rebuilt lines shifter and cables dip stick tube etc
and the kits that were used
Old Jun 5, 2008 | 06:50 AM
Cgroh89's Avatar
Engine: lt1
Re: Fresh 700r4
bumpage
Old Jun 6, 2008 | 07:00 PM
Cgroh89's Avatar
Engine: lt1
Re: Fresh 700r4
Bump,
Had alot of people interested in pms but no one had made an offer on it
Old Jun 8, 2008 | 03:06 PM
Cgroh89's Avatar
Engine: lt1
Re: Fresh 700r4
Bumps 600$
Old Jun 11, 2008 | 07:50 PM
Cgroh89's Avatar
Engine: lt1
Re: Fresh 700r4
Bump. Make an offer I found some rims that I want ( hint hint )
Old Jul 28, 2008 | 07:13 PM
KamikazeIroccy's Avatar
Car: '87 Iroc-Z
Engine: 355cid Cam'd
Transmission: T5 Manual
Axle/Gears: Stock 9 Bolt
Re: Fresh 700r4
willing to ship to missouri? will it ifa 87 Iroc
Old Jul 28, 2008 | 07:44 PM
Cgroh89's Avatar
Engine: lt1
Re: Fresh 700r4
You would need to check which trans your car has You will need to use your your tv cable hardware .
I could check on shipping though I am sure it will not be cheap It will most likely be on a pallet with shirk and banded.
Old Jan 19, 2009 | 10:45 AM
Cgroh89's Avatar
Engine: lt1
Re: Fresh 700r4
I just got rid of my t56 and installed a built 4l60e along with a computer and harness swap so I cant use it anymore even if I kept it around
You will need to reuse your tv cable bracket, for some reason I mis placed mine
Old Jan 21, 2009 | 05:56 PM
Cgroh89's Avatar
Engine: lt1
Re: Fresh 700r4
ttt
Old Mar 24, 2009 | 03:31 PM
Cgroh89's Avatar
Engine: lt1
Re: Fresh 700r4
How can I not get rid of this! I want some wheels
350 bucks get it out of my garage!
Old Mar 24, 2009 | 08:55 PM
ajk511's Avatar
Car: 1991 z28
Re: Fresh 700r4
Chris call me. I might take it for $350 if its done rebuilt and ready to roll. need a stronger trans for the zz383
Old Mar 24, 2009 | 10:25 PM
alscamaro89's Avatar
Car: 89 iroc
Axle/Gears: posi
Re: Fresh 700r4
i would be interested for that price if you still have it. i am looking at buying a car with a blown motor n trans so i would need a trans for it. let me know if you still have it, thanks
Pac J
May 17, 2020 10:44 AM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
6998poncho
Sep 25, 2015 02:56 PM
