serpentine belt set-up
Old Jun 12, 2008 | 06:52 PM
laintocable's Avatar
Car: 89 firebird
Engine: 400 sbc/forged/alum/supercharged
Transmission: TH350, manual valve body
Axle/Gears: posi 390/4 whl disc
serpentine belt set-up, includes brackets,bolt,alt,a/c compressor,smog pump,crank pulley,waterpump pulley,p/s pulley & belt tensioner. $150+shipping (some parts scraped to bear metal,need painting to suit your color, was going to use but decided not to, went v-belt)
Old Jun 15, 2008 | 10:49 AM
Car: 89 firebird
Re: serpentine belt set-up
bump!
Old Jun 15, 2008 | 11:08 AM
F-Body_Fetish's Avatar
Car: 1984 Camaro Z/28
Engine: 350 SBC
Why did you go V-Belt instead? any advantage between the two?
Old Jun 15, 2008 | 12:02 PM
Car: 89 firebird
no not really, but i'm using a 400 sbc with a blower and the serpentine belt lined-up in the way of the blower belt, so I wasn't able to use it, the only way was to go v-belt.
Old Jun 15, 2008 | 12:25 PM
Engine: 350 SBC
Well, i'm picking up a motor from Daz, it has the serpentine pulley on it. since the only accessory i have is the PSpump at the moment, would it be easier to get a serpentine setup and get a serpentine pump? or go V-Belt and get a new pulley and keep the pump? since i don't want to have AC or a smog pump or anything i only need to turn the water pump, alternator and PSpump. are V-Belt accessories more abundant? i dunno. which way would you go?
Old Jun 16, 2008 | 11:04 AM
Car: 89 firebird
if the only items you're using is alt,waterpump and p/s pump I'd go v-belt. Serpentine brackets take up more room and then you're going to have to find and a/c & smog pump delete pulleys.
Old Jun 16, 2008 | 08:34 PM
mxthreat's Avatar
Car: 86 iroc
Engine: 383
Transmission: automatic
Axle/Gears: stock
do you still have this setup? and do you have the water pump
Old Jun 17, 2008 | 06:51 PM
Car: 89 firebird
I still have the set-up, but I'm sorry the waterpump stays with the engine. And I have a few guys interested in the engine...
Old Jun 18, 2008 | 06:38 PM
Car: 89 firebird
sell pending...
Old Jun 19, 2008 | 01:04 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Hey,
I'm looking to put an ATI Procharger suprecharger on my 86 IROC with the V-Belt system. Unfortunately, it is not compatible iwth the V-Belt system so I need to convert to Serpentine system.
I have an 86 IROC-Z 305TPI Auto 700R4. I will need A/C and smog pump delete pullies, this I am aware of.
My question to you is this: Is this set-up complete from A to Z if I were to purchase this from you? Or would I need to purchase other things like bolts, brackets, water pump, etc... And can I use my current aluminum water pump with this system?
Thanks!
-Marc
Old Jun 19, 2008 | 04:43 PM
Car: 89 firebird
I'm waiting for a responce from 85monteZZ4 if he doesn't come through you're next in line...The system is complete from A to Z, (exceptions: no waterpump, no power steering pump) pulleys yes and of course everything mentioned up top.. Your waterpump will not fit because on v-belt systems the waterpump is forward rotation and on serpentine systems you need a reverse rotation waterpump..the engine blocks are the same so you'll need a 89 firebird 305/5.0L with engine vin code E waterpump. They ask you engine code at the parts house, even though it doesn't matter, 5.0L & 5.7L are both still SBC's..(small block chevy)your power steering pump will work, all you have to do is press the pulley on... I'll let you know what goes down with my first client...
Old Jun 20, 2008 | 04:38 PM
Car: 89 firebird
Sold!!!!
jrdturbo
Mar 31, 2016 02:58 PM
sparks454
Interior Parts Wanted
Oct 18, 2015 03:18 PM
SRKLEGIN
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
