Comp Cam Xtreme Energy XE268H and workover 416 heads
Car: 99 Mystic Green Trans am
Engine: LS1: Heads, MS4 cam, bolt'ons
Transmission: Fully built T-56 w/Spec3 & Pro 5.0
Comp Cam Xtreme Energy XE268H Hydraulic Flat Tappet Camshaft
Lift: .477''/.480'' Duration: 268°/280° RPM Range: 1600-5800
Makes a 305 sound GOOD! Lifters included and were kept in order.
750 miles on parts. - $95 shipped
Some moisture got in the bag I thought were sealed.
So the heads have a little rust on them and will need to be cleaned and less then not, milled again. heres what was done to them
416 heads with 3 angle valve job and gasket matched.
mild down a little for some more compression.
Exhaust port valves changed with stock size Manly valves.
Also heads now have bolt in APR rocker arm studs
Done by a reputable shop that races their cars in all the
competitions down here.
Comes with shop's brand of Springs and retainers good for .500 lift
maybe .550 lift I'm not sure. I was running .477''/.480'' without a problem.
2000miles since work.
will let them go for - $250 shipped
Re: Comp Cam Xtreme Energy XE268H and workover 416 heads
heads
Car: 85 Camaro
Engine: forged 383 11:1
Transmission: T56 TDP STAGE 2
Axle/Gears: 99 ws6 3.42 posi rear
Willing to sell the cam and lifters shipped to nj for any less than 95? I have 80 extra dollars burning a hole in my pocket but dont have 95 right now!
*bump*
Need these two items gone by the 10th.
PM me if your interested at all.
TTT
ambainb
Apr 25, 2016 09:21 PM
