aluminum 113 heads
Old Aug 19, 2008 | 12:06 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
aluminum 113 heads
they have @ 85k miles on em, totally complete. Came off a perfect running motor . I live in Chicago Il by Midway Airport. Looking for $450 . I can take pics if anyone is interested. thanks
Old Aug 19, 2008 | 01:56 PM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
Re: aluminum 113 heads
i assume they were not redone, magnafluxed ect?? id give you $250 shipped. it would take about $250-$300 of work to clean them up, nobody puts 85k mile heads on there car without getting them redone first.
Old Aug 19, 2008 | 02:17 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
$250 shipped... are you serious? If you come pick em up Ill sell em for $400
Old Aug 19, 2008 | 02:26 PM
8T9 BANDIT's Avatar
Car: 1989 T/A
no way guy, look around they go for $400 already redone. GOOD LUCK!
Old Aug 19, 2008 | 02:47 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
I look all the time,,,, never have they ever sold for less than 650 done up new, and that was only once and they sold in less than a week. Dont try to BS me. thanks for lookin though
Old Aug 19, 2008 | 11:52 PM
RandyJ75's Avatar
They cost $1000.00 new.
Old Aug 20, 2008 | 08:20 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Thanks, Im deffinetly not in a hurry to sell them now,,, the set of trick flows I was going to pick up this weekend got sold before I could get down there.
Old Aug 20, 2008 | 12:29 PM
86speediroc's Avatar
Transmission: 94 t56
Axle/Gears: 3:42 10 bolt
i gotta say 400-450 shipped is fair honestly they are only about $30 to ship and any 113 set of heads w/o damage is worth about $350-400 short of any damage and machine work redoing a set of heads can be done yourself for about $250 including new valves/springs/locks,retainers and seals and thats using good parts
Old Aug 20, 2008 | 12:31 PM
8T9 BANDIT's Avatar
Car: 1989 T/A
dont forget hot tanking and magnafluxed. another $200. im actually now looking at trick flows 56cc street heads for my lb9.
Old Aug 20, 2008 | 05:42 PM
thirdbirds's Avatar
Car: 87gta 88notch 89 5spdgta 92 vert
Engine: 5.7
Hot tank aluminum heads, no !!!!
Old Aug 20, 2008 | 08:23 PM
redbandit98's Avatar
you can tank them, just not in the same chemical as the normal hot tank. Most places wont have the setup for both though.
Old Aug 20, 2008 | 09:13 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
most machine shops Ive asked use caustic soda in the hot tank, big time no no for aluminum.......... Sold!!!! :-). thanks guys
Old Aug 20, 2008 | 10:55 PM
SS5150's Avatar
Car: '88 Monte Carlo SS
Do 113s have guideplates?
Old Aug 21, 2008 | 07:14 AM
gmtofd's Avatar
On ZZ series crate mtrs #113 heads come with non-harden guide plates along with self aligning rockers. They really don't act as guide plates at all.
Posted as set of #113's off my low mileage ZZ3, for $650. They had some machine work such as a nice radius valve job and the valves were undercut more than what Chevy does to them, the intakes were pocket ported, new seals that go on top of the guides along with "o" ring type seals for the intakes, Isky springs, machined steel retainers, and correct harden guide plates for use non-self aligning roller tip rockers. The reason for selling them was that the chambers cc'd at 56 and the static compression was going to be a little high at 10.5:1. There was some interest and probably if I bothered to post some pics, they would of moved, but decided to bolt them on and see what happens.
Old Aug 21, 2008 | 08:21 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
for $650 thats a great price, Id bet those would have sold within 3 days, the 113 heads I sold had non hardened guide plates but they are still guide plates,,, never use SA rockers and guides plates, the only difference with hardened guide plates is you need hardened pushrods.
Old Aug 29, 2008 | 07:05 AM
gmtofd's Avatar
The non harden guide plates that come with the #113's have a wider slot, than normal. That why they are really not considered guide plates at all. They just like of hold the push rod in place in case some thing fails in the valve train.
Believe your right about using harden push rods along with guide plates.
Old Aug 29, 2008 | 11:29 AM
robert1's Avatar
I can't tell between all the arguing, but are these sold then???????
Old Aug 29, 2008 | 03:30 PM
87SSTPI's Avatar
Car: 1987 Monte Carlo SS
Engine: Vortec headed 350
Transmission: '89 WC T5
Sometimes I get a kick out of "arguing". So please let me know where that has taken place in this thread. (?)
Old Aug 29, 2008 | 07:40 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Yes there sold.... there hasnt been any arguing,,, just read what I say,Im always right..lol. Search the forums for building a 305 instead of a 350 and youll see some arguing.
Old Aug 30, 2008 | 09:18 PM
Joes1wood's Avatar
Car: 1985 Camaro Z28
Engine: 5.7 Liter
Axle/Gears: 10 bolt 3.55 POSI
These are the 350 corvette heads with 58cc chambers that can go on to 305s correct?
Old Aug 30, 2008 | 09:20 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
yes u can use these on 305s but this guys set is sold
lt500r55
Sep 1, 2021 01:30 PM
Reddeath210
Oct 6, 2015 08:20 AM
italiano67
Aug 31, 2015 06:04 PM
z28addict8490
Aug 7, 2015 08:48 PM
