some auto trans stuff i no longer need take a look
Car: 92 Camaro RS
Engine: 383
Transmission: t-56
Axle/Gears: 4.11
ok so here goes i got a list of some parts im gettin out, if anyone wants before i throw out.just give me an offer and its prol yours.pictures on request with serious offer.all parts +shipping,will meet localy if not to far.willing to negotiate.any reasonable offer will not be refused thought id give you guys dibs before the trash i no longer need these parts!
i got a edlebrock performer rpm T.B.I intake manifold its like new heres the link
http://store.summitracing.com/partde...5&autoview=sku
its 254 brand new id like to get 180 out of it has barely been used i swapped over to a carb to fast to use it long.
i have a stock tbi carb from a 305, works perfect no sticking or anything i just went to a holley 650 dp so i have no use for it, make an offer.
i have a B&M megashifter for the F-body basically brand new no scratches dings missing hardware used the lube so the metal didnt fuse together rubber boot has no wear or scratches, comes with the modified plate for the console pre done, its ALL there.was installed correctly im swapping to a 6 speed will have no use. heres the link its for a 82-92 console.
http://store.summitracing.com/partde...&view=32&N=700+
was 200+new want to sell for 150+shipping
Transmission Core (trans internals are basically shot)
From the outside it looks like a 700r4 but it might be a th350 either way internals are shot selling it for a cheap core. make an offer.
i got a holley 650 DP kickdown bracket and swing arm (two seperate peices you need both to get the right swing so you dont burn up the trans.) links below
both for 35$.
i do have a stock stall converter 1300 i believe is stock and will be selling the pedals and everything off the trans i no longer need just make an offer.
and i have a holley fuel rail for the dp applications.
i realize most of this no one needs but i thought id see if someone wanted any of it before it goes into the can......Thanks,John
both for 35$.
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Re: some auto trans stuff i no longer need take a look
How bout a pic of that megashifter
Car: 92 Camaro RS
Engine: 383
Transmission: t-56
Axle/Gears: 4.11
sale is pending on the megashifter...i will get picks up asap i should be out to the car today...its exactly like it would be out of the box...
Car: 92 Camaro RS
Engine: 383
Transmission: t-56
Axle/Gears: 4.11
I guess shifters back for sale dunno if the guy still wants it linkages are pending
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
