85 Iroc parts list and price
Car: 91 Purple Z28
Engine: 5.7 TPI
Transmission: 700 R4
I just parted out a 85 Iroc. Heres a quick list of parts and prices that I have.
TPI Harness (85) $125 *hard to find* only made 1 year
TPI Computer (85) $50 *hard to find* only made 1 year
TPI Induction (runners, intake, fuel rail, injectors, plenum) $225
Mass Air $75
Disc rear end 9 bolt ( needs caliper on one side) $150
pass fender in primer $50
Front nose with headlight bar and lower ground effect $200
Complete Console $75
wiper arms $10
Brake master cylinder with proportioning valve $50
wiper motor $20
Exhaust system (y pipe back) $30
Iroc Hood with louvers $75
ttops $50
steering Column with wheel $100
gound effects ($depend on which peice) or $100 for set
prices are negotiable, email me if something you need ...that i may have. Big stuff must be picked up. can get pics
Mass Air $75
wiper arms $10
wiper motor $20
ttops $50
Car: 91 Purple Z28
Engine: 5.7 TPI
Re: 85 Iroc parts list and price
also have a completely rebuilt 700r4 out of a 89 rs. Never installed, just recently done. $500
Do you have a flywheel for 305 with the 2 piece rear main seal? Also need a good clutch for same.
email to apache@strato.net Thanks
Last edited by apache3132; Sep 27, 2008 at 07:11 PM. Reason: Automerged Doublepost
Car: 91 Purple Z28
Engine: 5.7 TPI
do you need the small or big flywheel? motor turned out to be a 350. flywheels are pretty cheap at local parts store. at least they use to be. it also had a auto tranny...no manual
Car: 91 Purple Z28
Engine: 5.7 TPI
yes...tilt steerin column, not sure about the louvers...i know they have a couple broken studs. i think i may keep the hood and louvers anyway for my 89 rs.
Car: 87RS/70 novaSS/85 Z28
Engine: 2.8L/468 HP unknown/HO305
Transmission: 700r4,T400,stock
Axle/Gears: stock,fab9,stock
need the hood. sent to 98277 have pay pal what color
Car: 91 Purple Z28
Engine: 5.7 TPI
speedo was swapped out with a 85...so nobody probably wants that..lol..the rear end is suppose to be posi im assuming, but i know when i layed a black mark in my garage before stripping the car, it only laid one mark. so not sure what the deal is with that.
As for the hood, it will have to be picked up...and that may be a long drive if your from WA.
1992 Trans Am
May 10, 2023 07:19 PM
Linson
Aug 21, 2015 02:12 PM
mustangman65_79
Aug 11, 2015 03:17 PM
