Mallory 6AL #6853M Ignition
I have a slightly used Mallory 6AL ignition box. It works perfectly and has a rev limiter. In my opinion this box is a lot better than the MSD 6AL. With this box you don't need rev limit pills, it is as simple as turning a dial. I would like to get $125 shipped to the lower 48. I will post pics later.
From Summit:
Brand: Mallory
Product Line: Mallory HyFire VI-AL Digital CD Ignitions
Part Type: Ignition Boxes
Part Number: MAA-6853M
Ignition Box Output: Capacitive discharge
Circuitry: Digital
Rev Limiter: Yes
Timing Retard: None
Data Acquisition: No
CD Voltage Output to Coil: 520 V
Current Draw: 0.6 amps per 1,000 rpm
Spark Output (millijoules): 135 Millijoules
Minimum Operating Voltage: 8 V
Maximum Operating Voltage: 16 V
Length (in): 8.000 in.
Height (in): 2.750 in.
Width (in): 3.500 in.
Ignition Box Color: Red
Coil Included: No
Warranty: One-year warranty
Quantity: Sold individually.
Notes: If this ignition is used for racing the warranty is 90 days.
Ignition Box, HyFire VI-AL, Digital, Capacitive Discharge, Universal, Magnetic Trigger Applications, Each
Check to make sure this part fits your application When limiting is a must.
Digital performance at analog prices! That's what you get from the HyFire VI-AL ignitions from Mallory. Mallory has taken their VI-A ignition box and added an easy-to-adjust digital rev limiter that adjusts between 4,500-12,000 rpm, and doesn't require chips. They use the newest microprocessor-controlled circuitry to deliver more power and quicker acceleration with less current draw. These highly efficient ignitions deliver multiple sparks per combustion event, so you get consistent, reliable performance throughout the rpm range. The durable, lightweight, extruded aluminum housing ensures maximum heat transfer. They are easy to install and work with points, OEM, or aftermarket electronic ignitions, or magnetic crank triggers.
From Summit:
Brand: Mallory
Circuitry: Digital
Rev Limiter: Yes
Timing Retard: None
Coil Included: No
Hotrodboba400
12-10-2019 07:07 PM
RedLeader289
05-28-2019 01:47 PM
Gunner242
12-25-2015 04:49 PM
2012sergen11
10-13-2015 07:38 PM
