Complete TPI Set-up from an 85 Corvette
Old Nov 25, 2008 | 07:28 PM
RacerDad916's Avatar
Car: 89 Z28
Engine: 355 full roller, Brodix 10X heads
Transmission: Close ratio Muncie
Axle/Gears: 3.42/7.5
The following items are a complete bolt-on TPI setup for SBC. Our motor produced 493lb-ft with this setup. We are switching to a carburetor, so all the TPI stuff must go. We want to sell the whole thing as a package if possible.
Edelbrock High Flow TPI Intake - Larger ports to match SLP Runners. Bolt holes are slotted to work with both early & late non-vortex heads.
SLP Cast aluminum Intake Runners (Polished) - Port matched to Edelbrock base.
Upper plenum (Polished) - Ported to match the SLP Runners.
Stock Fuel Injectors w/ fuel rails - Injectors Blue Printed by TPIS
Adjustable Fuel Pressure Regulator
Stock 48mm Throttle Body w/ air foil added.
Stock Mass Airflow Sensor w/ screens removed for better flow.
Stock distributor for use with TPI.
Complete engine wiring harness from 1985 Vette for fuel injection + all sensors & gauges.
Complete dash wiring harness for 1985 Vette, including ECM.
The cam we used for this combo is also available. PM me for specs and price
I will consider trades for a 4150 sreies 750cfm carb and a Victor Jr intake and some cash.
Billy
Old Nov 26, 2008 | 08:48 AM
Dangerousdan's Avatar
Want a title? Post!
Re: Complete TPI Set-up from an 85 Corvette
If I could afford it? HOW MUCH!
Old Nov 27, 2008 | 10:16 AM
Car: 89 Z28
asking $950 cash or Paypal.
Old Nov 27, 2008 | 11:40 AM
mxthreat's Avatar
Car: 86 iroc
Engine: 383
Transmission: automatic
Axle/Gears: stock
what heads were you using???
Old Nov 27, 2008 | 10:29 PM
bspvette's Avatar
Want a title? Post!
We were using stock aluminum heads from my '86 Rag top Vette. The only work done was to match the ports on the intake.
This combination really rocked, but we are moving the car to a class that favors carburetors. If you're looking for a reliable TPI setup with great power, this stuff will do the trick.
(I'm answering for RacerDad since he is away for the holiday.)
Thanks,
BeerMan
Old Nov 28, 2008 | 02:30 PM
87whiteiroc's Avatar
Car: 87 Camaro
Engine: 5.7 350 TPI
pics?
Old Nov 28, 2008 | 03:16 PM
bspvette's Avatar
Want a title? Post!
I'll try to get some pictures posted tomorrow afternoon. Sorry for the delay.
Thanks,
BeerMan
Old Nov 29, 2008 | 06:03 PM
bspvette's Avatar
Want a title? Post!
I took some pictures this afternoon, but I'm not smart enough to know how to post them here.
I can Email them to you if you give me an address. I am happy to post them here if someone wants to help me with that.
Thanks,
BeerMan
Terrell351
Jun 13, 2021 01:13 PM
Caspar
Jun 19, 2016 11:19 PM
Casey Meyers
Mar 2, 2016 10:46 AM
KO1
Aug 31, 2015 06:31 PM
Sanjay
Aug 12, 2015 03:41 PM
