[Sold] Changing Setup and Cleaning house, heads, ca
Old Dec 14, 2008 | 09:22 PM
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
$700 Ported Pro-action 180’s
Less than 10k miles since port work and a valve job 280/202 cfm at .6 lift. Springs set up for 135lb seat pressure so good for flat tappet or roller hydraulic lifters
$350 3800 Stall TCI stall for 700r4/4L60E
$125 Cam Motion Blower/EFI Nitrous Grind Cam 236/245 @ .050 .495/.507 112LSA.
$250 LT1 Intake converted over to run on SBC, includes remote thermostat, hoses, and fuel rails but no fuel lines. It has been ported to a 58mm TB and 1205 intake gasket. Ran for 15k miles w/o any issues.
$150 58mm BBK throttle body for an ’88 TPI
$50 Gutted TPI MAF Worked good when pulled, switched to SD.
$60 165 ECU with 88 350 chip
$100 Set of 15x7 cross lace style rims, two still have some decent tires on them. Painted gold
$25 Mag lug nuts for the above rims.
$150 TPI Intake, fuel rails, and Throttle body.
$50 LS1 injectors
$650 Pro Stars 15x3.5 and 15x8 with 3” backspacing. Didn’t rub on my GTA, but close. Metric 165’s in front and 26” ET Streets in the rear. Include once used Summit open ended lug nuts for 12x1.5mm studs.
$75 or trade for a Snell 2000+ helmet. XL Silver KBC VR1-X Helmet
http://www.motorcyclecloseouts.com/s...graphic+helmet
$80 Fleshgear Black Textile jacket XL. Worn 3-4 times if that.
http://www.motorcyclecloseouts.com/s...ort+tx+jacket#
$80 16x Trickflow Chromoly pushrods 3/8 7.900" length should be +.100 for a SBC, half used for test fitment, half ran for less than 10k miles
$40 Stud Girdle for a SBC
$60 8x 1.5 Crane Gold roller rockers well worn
$350 Nitrous Setup for EFI. Shark Nozzle and NX noids, 15lb NOS bottle. FP Switch, WOT switch, bottle heater, and enough lines to plumb it up.
$50 MSD Digital Window Switch
$50 2x10"JBL subs in Box, fits in a fourth gen fine.
Old Dec 15, 2008 | 09:53 PM
Roostmeyer's Avatar
Axle/Gears: 3.70
Re: Changing Setup and Cleaning house, heads, ca
I didn't have any time to clean anything up tonight due to my unheated garage but here are some pics. I haven't sold anything on here since I started in FSAE, but I think I've still go some feedback under my full name on the feedback board.
Old Dec 30, 2008 | 11:18 PM
Roostmeyer's Avatar
Axle/Gears: 3.70
more pics, more parts, lower prices!
$650 Ported Pro-action 180’s
$900 408 short block needs new bearings and rings. .040 over block, eagle crank, ohio crank 4340 rods, Ross -20cc pistons. Motor has less than 10k miles on it.
$300 TCI 3800 Stall for 700r4/4L60E
$400 700r4 with shift kit rebuilt less than 7k miles ago
$100 Cam Motion Blower/EFI Nitrous Grind Cam 235/245 @ .050 .495/.507 112LSA.
$225 LT1 Intake converted over to run on SBC, includes remote thermostat and hoses, but no fuel lines. It has been ported to a 58mm TB and 1205 intake gasket. Ran for 15k miles w/o any issues.
$140 58mm BBK throttle body for an ’88 TPI
$125 Serpentine acessories and brackets for thirdgen. Underdrive crank pulley, polished alternator(was a reman before I polished by hand) water pump has been replaced as well.
$20 SBC Stock starter for 158 tooth flywheel
$60 Mini Starter unsure of brand
$40 Gutted TPI MAF Worked good when pulled, switched to SD.
$50 165 ECU with 88 350 chip
$85 Set of 15x7 cross lace style rims, two still have some decent tires on them. Painted gold
$15 Mag lug nuts for the above rims.
$125 TPI Intake, fuel rails, and Throttle body. Polished top, painted runners
$40 LS1 injectors
$125 30lb Red top SVO injectors
$600 Pro Stars 15x3.5 and 15x8 with 3” backspacing. Didn’t rub on my GTA. Metric 165’s in front and 26” ET Streets in the rear. Include once used Summit open ended lug nuts for 12x1.5mm studs.
$60 or trade for a Snell 2000+ helmet. XL Silver KBC VR1-X Helmet worn 4 times
$80 Fleshgear Black Textile jacket XL. Worn 4 times
$75 16x Trickflow Chromoly pushrods 3/8 7.900" length should be +.100 for a SBC, half used for test fitment, half ran for less than 5k miles
$35 8x 7.900 3/8" pushrods less than 15k miles
$35 8x 8.000 3/8" pushrods less than 10k miles
$25 Stud Girdle for a SBC
$60 8x 1.5 Crane Gold roller rockers, worn
$75 8x 1.5 Lunati roller rockers same as crane's just blue
$75 8x 1.6 Crane gold roller rockers
$350 Nitrous Setup for EFI. Shark Nozzle and NX noids, 15lb NOS bottle. FP Switch, WOT switch, bottle heater, I’ll throw in some switches and relays.
SOLD MSD Digital Window Switch
Jeremys87
Jul 14, 2022 09:08 PM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
gta90
Sep 15, 2015 04:00 PM
Street Lethal
Aug 13, 2015 08:28 PM
