Complete 383 sbc 400+hp
Old Jan 20, 2009 | 09:51 PM
406 S10 Man's Avatar
Car: 1971 Corvette
Engine: 6.0 LS1 L92 heads sheet metal etc.
Transmission: M21 4-speed
Axle/Gears: 3.36
The engine for sale is a 388 (its bored .040 instead of .030 like 383s). It's based on a pre-86 block with a two piece rear main seal and two bolt mains. The mains are studded with ARP studs. The crank is an Eagle unit with 3.750" stroke. Rods are Eagle H-beams and pistons are Keith Black hypers. The compression is 10.25 and it runs great on premium. There is a stock 8" balancer on the crank. The whole assembly was professionally balanced.
We used Vortec heads on this motor but had 2.02/1.60 stainless valves installed. The valve guides have been machined for at least .550" valve lift clearance. Stock self-aligning rockers actuate the valves.
The can installed is a Comp Xtreme Energy 268. 224/230@.050 and .477/.480 lift. Here is a link to the specs http://www.compcams.com/Cam_Specs/Ca...x?csid=86&sb=1
I also have a 284 cam from the same line if the buyer wants it.
The intake is an Edelbrock Air Gap, the real thing not a Chinese knockoff, and the carb is a Holley 750 with electric choke. It has an aftermarket HEI distributor and MSD wires.
The Proform valve covers and air cleaner go with the engine and so do the accessories. It also comes with a $200 gear reduction starter.
The motor runs great and we have not had any problems with it. the only reason we are selling is that we're going to try an LS1 swap. It has pushed this 3400 pound Camaro to 13.40s at 104mph but that was before the valve upgrade so it probably makes a little bit more power now.
This would be a great deal for someone who has a V6 and wants to step up to a V8. The Hooker headers are included some parts for a y-pipe are too.
Price is $1700 and I can ship anywhere for a $50 crating fee plus the actual shipping amount. I pulled it two months ago so I could get it ready for shipping right away.
Old Feb 24, 2009 | 04:48 PM
duggish's Avatar
Want a title? Post!
Re: Complete 383 sbc 400+hp
I know this is an old post, but do you still have the motor available?
Old Feb 24, 2009 | 05:58 PM
Car: 1971 Corvette
Axle/Gears: 3.36
I should be shipping that out to a member here tomorrow. I should have updated the thread but I just got the check.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
tonys91rs
Sep 2, 2015 07:07 PM
