[OH] Walbro 255lph GSS340M Pump,Racetronix harness & sending unit
Car: 1970 Nova
Engine: 850HP 383
Transmission: TH400 w/ Brake
Axle/Gears: 4.88 12 Bolt
FL98-FPA
Fuel Pump and Racetronix Installation Kit
Walbro GSS340M Pump
Filter sock - 30 micron filtering is better than factory
Walbro GSS to GM power adapter
High-pressure fuel line
Gear clamps
Rubber pump mount
Sound dampening sleeve
FL98-FPWHG-2
Racetronix
Plug and Play Wiring Harness
Plug & play (no soldering or crimping required)
Waterproof Delphi Weatherpack connectors
Heavy 10 gauge stranded copper wire
Tyco 40A weather-proof relay
Weather-proof Delphi fuse holder w/custom SS stud
Alternator-direct hookup for maximum voltage
Silicon grease, spare fuse and wire ties included
Optional body ground upgrade w/brass battery nuts
Also comes with sending unit and stock pump from a 91 GTA.
Whole setup $200 shipped
Setup brand new in package
Walbro GSS340M Pump
Gear clamps
Rubber pump mount
FL98-FPWHG-2
Racetronix
Car: 1991 Camaro RS
Engine: 3.1L
Transmission: rebuilt 700r4
Re: Walbro 255lph GSS340M Pump,Racetronix harness & sending unit
i know you probably dont want to, but would you be interested in selling just the fuel pump.
Car: 1970 Nova
Engine: 850HP 383
Prefer to sell as whole setup unless I find out new car will work w/ pump then Ill sell harness.
Heres some pics on the Racetronix site
http://www.racetronix.com/RX-FL98-FPKG-2.html
Ghettobird52
Jul 5, 2024 11:18 PM
ambainb
Apr 25, 2016 09:21 PM
