pro-comp cnc heads for sale
Old Feb 1, 2009 | 03:21 PM
joshmack's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 377: comp 10.5:1
Transmission: 350 turbo- 8 inch Coan
Axle/Gears: 10 bolt-373
190CC INTAKE RUNNERS
64CC COMBUSTION CHAMBERS
2.02 INTAKE AND 1.600 EXHAUST STAINLESS SWIRL POLISHED VALVES
1.460 DUAL VALVE SPRING ASSEMBLY
BOLT ON - READY TO RUN
500 HP + CAPABLE
Cylinder Heads PRO COMP 190cc Intake Runner Aluminum Cylinder Heads With 64cc Combustion Chambers. Hardened valve seat inserts w/ multi angle seats. Solid bronze valve guides.
Combustion Chamber 64 cc
Springs Isky 1.460" Dual Spring Assembly. Suitable for Mechanical Flat Tappet or Hydraulic Roller 140 PSI Closed / 360 PSI @ .500 lift Optional Hydraulic Flat Tappet Spring Package is Available With A single 1.460" Spring w/ Damper.
Spring Cups Chromoly Steel Valve Spring Locating Cups
Retainers Chromoly Steel Valve Spring Retainers
Guide Plates Hardened Steel Flat Guiplates for 5/16 Push Rods
Rocker Studs 3/8 x 24 Screw In Rocker Studs
Valve Locks Comp Hardened 7 Degree Locks
Seals Viton Positve Fit Valve Seals
Suggested Spark Plug .750" Reach Gasketed Autolite AR3910 or Equivalent
FLOW DATA @ 28" H20
PC3002 .100 .200 .300 .400 .500 .600
INTAKE 70 146 203 249 261 268
EXHAUST 57 101 157 176 186 190
I also paid $400.00 for a CNC option. I believe the flow figures above are for the stock heads, so they should flow a little better with the CNC option.
Only problem with one head is that the exhaust port has a thin line crack that you can't see. I was going to get this head fixed at the local shop, and they said 100.00 to fix the crack.
Since this happened, I came across a really good deal on another set of heads and decided to go with the other set. These heads have been sitting around for awhile and since times are tough here in MI, need to sell these. These heads are two years old and have less than 1500 miles on them.
Considering all reasonable offers.
Will post pictures soon.
Old Feb 1, 2009 | 06:22 PM
joshmack's Avatar
Re: pro-comp cnc heads for sale
500 HP + CAPABLE
FLOW DATA @ 28" H20
i can get the head fixed for 100.00 if someone needs me to plus the heads acourse. These heads are new, new someone will get a good deal.
Frozer!!!
Jan 19, 2024 04:55 PM
CRFred
Feb 7, 2016 11:39 PM
Reddeath210
Oct 6, 2015 08:20 AM
MoJoe
Sep 24, 2015 09:12 PM
Dialed_In
Aug 20, 2015 01:45 PM
