F.S. LT1 Long Block
Old Feb 14, 2009 | 01:12 PM
fryer1979's Avatar
Car: '79 Camaro; '84 Z28
Engine: 350; none
Transmission: TH-350, 2500 stall; none
Axle/Gears: posi, 3.08; disc, 3.23
F.S. LT1 Long Block
Any one interested in an LT1 long block? It ran well when it was pulled from a wrecked 1994 Z28 about 5 years ago. No visible rust issues, it has been garage kept and under plastic since pulled. Also has the timing cover and some odds and ends bracket as well as the motor mounts. I think it has the flex plate and oil pan, but I'm not sure, I will take some pics and post them when I get home this afternoon. I was going to use it myself, but I'm pretty sure I am going to use one of my Gen I blocks with an aftermarket injection system instead. $450 to any member, $550 for non-members. Thanks guys.
Old Feb 14, 2009 | 06:55 PM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Re: F.S. LT1 Long Block
Not high-jacking but I have an LT1 manifold for this long block if the buyer is interested. Also a set of iron LT1 heads. But first buy the engine. Would make good runner in a third gen.
Old Feb 14, 2009 | 06:59 PM
fryer1979's Avatar
Engine: 350; none
Sorry the photo isn't better, the weather is pretty bad up here and the motor is sitting in a dark spot in my shop surrounded by cars. It does come with an oil pan and flex plate, and the rust that appears visible is only a minor surface dusting on the water pump gasket surfaces. I'll get better pics when the sun is shinning again if it isn't sold by then.
midge54
Dec 27, 2019 04:14 PM
87iroctheo
Dec 4, 2016 11:47 AM
MoJoe
Sep 24, 2015 09:12 PM
fbirdroller
Sep 2, 2015 10:27 PM
gixxer92
Sep 1, 2015 04:32 PM
