Centerforce DF clutch for T5 and other stuff
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
ALL PRICES DO NOT INCLUDE SHIPPING, I AM LOCATED IN EDMONTON, ALBERTA, CANADA, ALL PRICES ARE OBO.
-Brand new in box Centerforce dual friction clutch, hasnt never been out fo the box, comes with brand new throw out bearing. sold
-Comp Cams 981-16 springs, with matching 742-16 retainers, and 601-16 keepers, All are brand new never been installed. (these springs are for most flat tappet applications, and will fit in the stock springs pockets) Asking 60$USD + shipping
-B&M high capacity 700R4 aluminum transmission pan, holds an extra 3 qts of ATF, ran for about 200 km's basically brand new, both filter extensions included along with bolts, with also throw in brand new pan gasket and filter - Asking 120$ USD + shipping
-Earls stainless braided brake hoses, for rear drum cars PN 28A180, 40$USD OBO
-Hawk fron brake pads for camaros/firebirds - 40$USD OBO
-Complete set of LT1 fuel injectors with new clips, 50k miles, very clean - $60 OBO
- Holley TPI AFPR, brand new never been installed - cant find orig box, but complete with instrutions - sold
- Pro comp electronics TPI dist, I replaced the POS pro comp module with an Accel, Brand new MSD cap and rotor on it. less than 250 miles on it. billet housing, very nice looking. - sold
- MSD 8.5mm Superconductor Red spark plug wires, 90 degree plug ends, these work awesome on tbi/tpi engines with headers, clear with no problems. Brand new sold
- MSD 6AL ignition box, BRAND NEW, never been mounted, wires never cut, comes with harware, pills, and jumper cable - 140$ OBO
- Eibach Sportline lowering springs, 1.6" drop in the front, 1.3" in the rear 3000miles on them, powdercoating is peeling where front sit ni the spring pockets, mint other than that - $100 OBO
- ZZ4 cam approx 500 miles, nice shape, il throw in a set of low miles gm roller lifters also - $100 OBO
- GM single roller heavy duty timing set for 87+ hyd roller blocks, this is the timing set you need for the 411 PCM swap, as the reluctor wheel will not clear a double roller - $20 OBO
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Centerforce DF clutch for T5 and other stuff
ill take the valve spring package.
Hawk312
Aug 22, 2017 08:55 PM
