TPI SETUP
Old Mar 18, 2009 | 12:54 PM
RESENDEZMARIO's Avatar
Car: 08 cobalt ss turbo, workin on iroc
Engine: 355
TPI SETUP
i have a tpi setup from my 350
manifold
runners----- SOLD
fuel rails ---SOLD
maf
throttle body
Old Mar 18, 2009 | 12:56 PM
Engine: 355
Re: TPI SETUP
Old Mar 18, 2009 | 02:13 PM
transamice's Avatar
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
Re: TPI SETUP
Would you sell the MAF seperatly?
What fuel regulator/ gauge do you have there?
Old Mar 18, 2009 | 10:23 PM
Engine: 355
Re: TPI SETUP
55 for the MAF sensor and im not sure wut kind of adjuster it is but its a neat feature, i'll look at it tomorrow and check.
Old Mar 19, 2009 | 09:23 PM
Engine: 355
Re: TPI SETUP
i also have a distributor
Old Mar 22, 2009 | 10:52 AM
Engine: 355
Re: TPI SETUP
tpi intake, runners etc.
manifold-$85
left runner-$25-------SOLD
right runner- $25----------SOLD
intake center collector-$35
throttle body-$65
fuel rails w/ adjuster-$75-------SOLD
maf sensor-$55
like new SVO 24lbs SVO's-$250
distributor w/ msd blaster coil-$60
computer-not for sell to further notice.
everything is plus shippin
thanks
Old Mar 24, 2009 | 07:40 AM
Engine: 355
Re: TPI SETUP
ttt
Old Mar 24, 2009 | 08:21 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: TPI SETUP
do you have the metal hoses that run from the gas tank to the runners. pm if you do.
thank you
Old Mar 24, 2009 | 08:56 AM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Re: TPI SETUP
Is the computer a part # 1227730? If so Im interested. Good shape and working when pulled? Prom included? I'm local so can pick up. LMK
Old Mar 24, 2009 | 09:43 AM
Engine: 355
Re: TPI SETUP
metal fuel lines
yea but i sold already
thanks for ur interest tho
Old Mar 24, 2009 | 09:44 AM
Engine: 355
Re: TPI SETUP
ttt
Old Mar 24, 2009 | 09:50 AM
Engine: 355
Re: TPI SETUP
ttt
Old Mar 24, 2009 | 09:56 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: TPI SETUP
That particular ECM 7730 is the same as alot of cars.. I believe they are
90's Grand am w/ 3.1 Litre Engine
90's Grand Prix w/ 3.1 Litre Engine
90's Cavalier w/ 3.1 Litre Engine
90's Firebird
90's Camaro
You have to ask the question on the Prom which numbers.. Like AUJP chip etc..etc.. Every prom number is going to be different depending on the style of car ie.. engine, trans, etc..
There are alot more, I just can't remember which ones
You just won't get the right Eprom.
Old Mar 24, 2009 | 10:49 AM
Engine: 355
Re: TPI SETUP
idk.lol
Old Mar 24, 2009 | 04:31 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Re: TPI SETUP
90's Firebird
90's Camaro
Correct me if I'm wrong but does the part that the chip plugs into a seperate piece? So since I have someone burning me chips I just need the 7730ECM and the part that the chip plugs into? Right or wrong?
Old Mar 28, 2009 | 09:37 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Re: TPI SETUP
The 7730 complete ECM and the G1 adapter are necessary. I have never heard of anyone running without the AUJP in the adapter. I know you need the OEM eeprom for the limp-mode. I am not sure if it will run without it. I also know the eeprom uses the ESC into the G1 adapter. Just remember to have your friend shut off the VATS when he burns your chip or you won't be able to start your car.
Old Mar 28, 2009 | 10:19 PM
FUNIROC's Avatar
Car: 1989 IROC
Re: TPI SETUP
How about $35 shipped for the Plenum to:
Woodstock, GA 30189
Old Mar 29, 2009 | 06:22 AM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Re: TPI SETUP
Thanks for the info.
Old Apr 2, 2009 | 03:13 PM
Engine: 355
Re: TPI SETUP
ttt
Old Apr 7, 2009 | 05:51 PM
Engine: 355
Re: TPI SETUP
ttt
stalkier
Dec 6, 2015 11:25 PM
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
