Testing waters 327 with 91 TPI SD intake setup
Car: 1987 Z28
Engine: LG4
Hi all,
im seeing if there is any interest in a 327 with a SD L98 upper half installed
specs:
--1968 block that was zero decked and checked for cracks and such
--bored .040 over to make it a 333ci
--2 bolt main
--summit 1103 cam 214/224 .442/.465 at 112LSA
--trw forged flat top pistons(-5.3cc)
--gm "pink rods"
--stock crank
--stock L98 heads
--stock 1991 l98 tpi setup with 24# injectors
--adjustable fuel regualtor(BBK)
the motor runs very well and is tuned(moats chip adpater)...but im looking to do a LT1 or LS1 conversion.
also up for grabs is a 3300 rpm stall for 700r4 and the trans itself
has weird isssue of not wanting to shift into 3rd at WOT.....you have to lift off the gas petal and let it shift anf then press gas down WOT. Under normal accel it shifts really good.
So again, im looking maybe around $1500 or trade for lt1/ls1 or maybe a truck 5.3L/6.0L ls series setup
entertaining ideas of tradeing the whole 1991 trans am for something esle
specs:
--2 bolt main
--gm "pink rods"
--stock crank
--stock L98 heads
Car: 87 IROC
Re: Testing waters 327 with 91 TPI SD intake setup
How did this combination perform? I was thinking of doing the exact same thing. I think we are a little far apart for me to purchase your set up but i would enjoy some feed back?
Car: 1987 Z28
Engine: LG4
the 3300 rpm stall with the current engine combo is too much and is lacking the low end grunt.
i plan one a HSR and a set of world product sportsmen II heads and larger cam for this summer......then by end of summer it will be time for a LS1 swap
1992rs/ss
Jan 31, 2025 05:10 PM
evilstuie
Jan 9, 2020 08:29 PM
Sanjay
Aug 12, 2015 03:41 PM
