[FL] camaro/aftermarket stuff
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
Re: camaro/aftermarket stuff
yep, your 'link' didn't show up. You might try again and do a test to be sure. Nitro
You will have to go to photobucket, type in tig57_photos it will say no matches but scroll down to tig57_ photo album, click on it and it will show you, promise. Briefly I have comp engineering sub frame connectors, lakewood traction bars, lakewood panhard bar, sphoon steering brace, jegs 10 bolt alum cover, s/s brake lines (metal and flexible) etc.
Car: '89 Trans Am GTA
Engine: TPI350
Axle/Gears: BW 3.27s
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
would you be willing to separate the shocks and struts? and how much?
Car: 1989 Iroc Camaro
Engine: Stock 350 TPI
sent you a pm about a arms and brake lines
Car: 1987 Trans Am GTA
Axle/Gears: 3.73's
Price on lower control arms, and if the sub frames will fit an '87 GTA, a price on those too. Thanks.
Car: 1988 Iroc Z28
275 for the shifter,rear cover,and brake lines ? email me at nighttrain379x@aol.com
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
if you can pm me the price and specs on the rearend, also price and what the gauge cluster fits (i need 1 to fit the newer styled wc t5 an 89 iroc to be exact).
also is the steering column tight? tilt in good working condition? cruise control column or not? price for it as well thanks gerry.
LT1Formula
Oct 8, 2015 08:34 PM
3rd, 85, 88, aftermarket, camaro, florida, gauges, gen, generation, inside, jacksonville, parts, sale, stuff, suspension, view
