2" spacers
Car: 87 Camaro
Engine: 5.7 350 TPI
2" spacers
i have some 2" spacers for sale. i had them on my 87 and upgraded to a 4th gen rear and have no use for them anymore. will take $65 shipped. pictures up tomorrow when i get them off the old rear
Car: 1990 Formula 350
Engine: 350 tpi heads cam full exhaust
Transmission: 700r4 corvette servo and 2800 stall
Axle/Gears: 342 out of a 00 SS
Re: 2" spacers
I was just wondering, what rims did you run and what was the offset?? Because I have a set of aftermarket ZR1s that have a 56 offset and with 2 in spacers the fronts rub on the tie rod and a part of my strut??
Car: 87 Camaro
Engine: 5.7 350 TPI
Re: 2" spacers
i have the original zr1s from the vetts and aftermarket ones that i have no problem with. check this website because i am unsure of my offsets and back spacing. http://www.skulte.com/adapterfaq.html
Re: 2" spacers
Its says I need a 2.25 spacer for the front. Thank You
Car: 1987 chevy camaro
Engine: 350 roller/edelbrock/holley carb
Axle/Gears: 3:42 open diff
Re: 2" spacers
any pics yet?the chart says i need 2" spacer for 93-97 wheels,but dosent say front or rear
Car: 87 Camaro
Engine: 5.7 350 TPI
Re: 2" spacers
i just know that the 4th gen wheels all need 2" spacers on both the front and rear to be able to fit. never heard or read anything saying different. Some of the corvette wheels might need 2.5s and for the camaro wheels, the 2" ones should do it.
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: 2" spacers
you take paypal? What wheels are you running? Are you using the 2" up front? I just swapped in a 4th gen rear, and I dont like how my old wheels sit now. So Im going to get a set of 4th gen wheels and I'll need 2 spacers for my fronts. just let me know
Car: 87 Camaro
Engine: 5.7 350 TPI
Re: 2" spacers
im running 17x9.5 zr1s in the front with 2" spacers and a 1" spacer on the 4th gen rear and 17x11 zr1s in the back. im switching to 1/2" spacer this weekend on the back. the 4th gen rear with the 9.5s do not need a spacer because the rear is about 2" wider each side. let me know if you want them.
Car: 88 IROC
Re: 2" spacers
I'll take them. Just tell me where to send the $65.
Do you have any good pics of your car? Id love to see how it looks with the Zr1s. I still havent made up my mind yet on what I want.
Car: 84 z28 h.o./ 92 rs
Engine: 305 h/o /3.1 v6
Transmission: hybird turbo 350/t5 bog warner
Axle/Gears: non posi 3.73 / ls 3.42
Re: 2" spacers
87 white if thirdgen dosent get them i can get them this friday ! do you have paypal ? let me know thanks !
