LS1 Rear Disk kit, complete
Old Jul 19, 2009 | 08:17 PM
simz28's Avatar
Car: 92 z28, 07 Silverado
Engine: LS1, 5.3
Axle/Gears: 3.73, 3.23
I have a rear disk kit from a 2000 Formula for sale. Everything worked great when I pulled it off the car. Everything needed for the swap is included. It could use a new set of pads, but theres still some life left on the ones there. The rotors could probably be turned too, but there not rusted bad at all. Asking $200 shipped.
Old Jul 20, 2009 | 01:01 AM
bungo78's Avatar
Car: 88' TA Digital Dash
Axle/Gears: 3:23 Posi Disk 10 Bolt
Re: LS1 Rear Disk kit, complete
PM'd
Old Jul 20, 2009 | 02:10 AM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
what else is needed to bolt them to my third gen iroc. i have a spec 3 iroc with offset rear rotors where on one side the rotors towards the front and the other side its towards the back
Old Jul 21, 2009 | 12:19 AM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
I may also be interested. Would these work for a 9-bolt? Do you have the required backing plates included?
Thanks,
Mike
Old Jul 21, 2009 | 01:43 AM
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
i have the same rear. are your brakes setup like mine
Old Jul 21, 2009 | 02:41 PM
simz28's Avatar
Engine: LS1, 5.3
The backing plates are included. This setup is everything you need. It will bolt directly to any 10 bolt with disk brakes, I dont think it will work with drums. But it will work whether or not you have the factory PBR setup or the iron calipers.
As far as the 9 bolt. It does have the right mounting spot, however you would have to redrill a couple holes on the backing plate, Its not hard to do.Other than that it would work no problem.
Old Jul 21, 2009 | 03:19 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Unfortunately, to use them on a 9 bolt, along with drilling the backing plates, you have to also press the bearings off the axles and use shims between the retaining plates and axle seals. Since the LS1 backing plates are aluminum, they are like twice as thick as the 9 bolt's and you need to make up the difference to hold the seals in.
Old Jul 21, 2009 | 06:48 PM
simz28's Avatar
Engine: LS1, 5.3
Wow my bad, I did not know that. I was going off of the PBR setup that I made to go onto a 9 bolt, I figured this would be the same. Thanks for the info
Old Jul 21, 2009 | 10:24 PM
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
sims ill buy your pbrs if you upgrade
Old Jul 25, 2009 | 06:05 PM
simz28's Avatar
Engine: LS1, 5.3
Im keeping the pbrs only because I already have brand new rotors and pads. In reality, this setup is better than the PBR's. The rotors are taller and much wider.
Old Jul 30, 2009 | 07:05 PM
simz28's Avatar
Engine: LS1, 5.3
TTT
Old Jun 26, 2010 | 05:21 PM
Dudeman1531's Avatar
Car: 91 Camaro RS
Engine: 383 FiTech
Transmission: T-56 BW
Axle/Gears: 3:42 10 Bolt
Still for sale?
Old Jun 29, 2010 | 11:32 AM
Wildebird's Avatar
THESE WILL WORK WITH A DRUM SETUP, JUST HAVE TO DRILL 2 HOLES ON THE AXLE TUBE PLATES. THATS WHAT I DID FOR MINE.
Old Jul 9, 2010 | 07:05 PM
jllee05's Avatar
Car: 91 camaro "RS"
Engine: 6.6L dart 400 SHP, DArt PRO-1 heads
Transmission: built 700r4
Axle/Gears: 3.73 posi!
please call me asap about this kit!!!, need it asap!!! thanks in advance!!
lee, (252)955-9968
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Terrell351
Jun 13, 2021 01:13 PM
Casey Meyers
Mar 2, 2016 10:46 AM
KO1
Aug 31, 2015 06:31 PM
TreDeClaw
Aug 14, 2015 06:58 PM
