[AR] Custom TPI Speed Density engine harness
Car: 1971 Camaro
This is a custom harness built by TPI parts uisng the original GM color scheme so it will be easy to trouble shoot with a shop manual.
This for the automatic SD TPI engine so it also also the VSS connector as well as everthing else needed to connected to your TPI and computer.
I did extend the harness to reach back to the battery tray of my 82 corvette, but it was done professionally using solder and heat shrink and the same wiring. I also added a heated o2 sensor pigtail and a electric fan relay pigtail.
It's got the works...$165.00 + shipping (lower 48) for the harness and instructions.
I have the ecm and TPI intake in another thread.
