SBC to LT1 T56 Ram aluminum flywheel
Car: S-10
Engine: Turbo 383 Mini-ram
Transmission: TH400
Axle/Gears: Ford 9" 3:89
For sale is a RAM Aluminum internally balanced flywheel for a Small block chevy to lt1 t56 conversion. This was purchased for $470. I am looking to get $335 shipped. I recently added a turbo to my setup which made it overpower my clutch I had. I went to a twin disk setup which requires a different flywheel. Because it overpowered the clutch, it started to slip so the flywheel did get a little hot so some resurfacing may be needed.
Car: S-10
Transmission: TH400
Re: SBC to LT1 T56 Ram aluminum flywheel
Now that I think about it you are probably correct. I can tell you though that it did not warp at all. I only had it in there a short time with the turbo on. My truck drove just fine and with out the turbo setup it grabbed great. Didn't really beat on my truck at all to much with this installed. Had a few runs at the track and a little screwing around on the street
ambainb
Apr 25, 2016 09:21 PM
