Thirdgen parts in MD dirt cheap
Hypertech TBI bowl paid 45 new - $10
Edelbrock reverse flow waterpump with pulley - $15
82-92 automatic shifter with **** and new switch - $10
Transmission cooler, used for 2k miles - $25
LT1 Flywheel for t56 with bolts - $30
82-92 automatic brake pedal assembly - $5
82-92 transmission crossmember - $5
Speedometer cable for 700r4 not even 100 miles on it - $15
Crank serpentine pulley $1
Autometer mechanical fuel pressure gauge ext mount, braided line - $10
Stock lower control arms, need sleeves in bushings - $5
Dash pad normal cracks - $10
Trunk shade little faded - $10
cruise control diaphragm with wiring and hose - $15
speedometer working reads 65359 - $30
New in box speedometer sending unit SUM G2887-1 http://www.summitracing.com/search/?...=g2887-1&dds=1 - $40
82-92 driveshaft with yoke, 4th gen u joint - $20
SBC 400 flexplate SFI approved - came with eagle rotating assembly about 1k miles still has the sticker on it - $20
Call Louis (301) 806 0595
Dont really feel like shipping the big stuff
Car: 1991 RS Camaro
Engine: 350 0.060" over
Re: Thirdgen parts in MD dirt cheap
Are you willing to ship the water pump? Indianapolis (46220)
Do you have a part # on it so that I can make sure it is the same as mine?
What is the pressure range on the autometer fuel press. gauge?
Car: 91 Rs
Engine: 383 hydrolic roller carb
where in md are you....I do you have a pic of the fuel pressure gauge
I can ship the water pump for 15 more dollars, and ill get the p/n, and the range on the fp gauge along with a picture by tomorrow
Car: 98 Camaro/85 Camaro
Engine: 3.8L/ 355 CI
Transmission: Auto/ TH350
Axle/Gears: 3.23 Posi
Is the automatic brake pedal assembly still available? Can you get a picture?
What is the p/n on the SBC 400 flexplate?
http://rides.webshots.com/album/5742...CeytP?start=12
Just saw that the waterpump was leaking out the hole so Im going to throw it away, sorry about that.
F/P gauge is 0-100 psi.
P/N on the flexplate is A617649.
The pedal assembly is still available (no rubber underneath the pedal cover.)
I am located in Bethesda.
Car: 1991 RS Camaro
No need to apologize, thank you for not selling me a broken water pump. I need a 0-10 gauge, so I'll pass on that.
Good luck with your other sales.
Car: 91 Rs
I will take the fuel pressure gauge. I live in Waldorf maryland....Do you live far from there.
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Hey man, hows your car running. im picking mine up later this week from the shop that is fixing my rust and my exhaust we should chill somtime
